Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 05-19-2015, 14:59   #91 (permalink)
Member: 2384272
Originally Posted by cellularman89 View Post
Here is a video of a note 3 oca process
ENJOY!!!
http://www.youtube.com/watch?v=l0D2lkdmbFA
Cellularman89. First i would like to thank your dedication.
Few questions:
1-) Tha vacuum laminator is very expansive. I am just begining this proccess. So, do you think it´s possible to do the process without the vaccum laminator and have good results?
2-) For now, i am not pulling off the lcd from the frame to avoid risk of cracking it. Have you ever done like this?
Old 05-19-2015, 15:32   #92 (permalink)
Member: 2384272
Originally Posted by rodrigo_maifer View Post
Samsung and Motorola.
i will try and post the result.
Thanks again
So. Let me tell what i have done until now.
i am trying to refurbish 2 displays.
LCD 01 is a Moto G
- put it in autoclave at 50ºC and 0.4 MPA for 40 minutes.
- No bubble, but they came back couple hours later
- as recomended, put in autoclave again at 20ºC an 0.4 MPA for 20 min
- No bubble, but some little bubbles came back couple hours later
- autclave for third time and fourth time, always 20ºc and 0.4mpa for 20 min.
- stiil have a very very little bubble at the bottom left corner.
LCD 02 is a Galaxy S4
- put it in autoclave at 20ºC and 0.4 MPA for 20 minutes.
- Many bubble still remaining
- Less bubble, but still many of them
- put it in autoclave at 75ºC and 0.4 MPA for 40 minutes.
- Almost no bubble and some came back couple hours
- Just one medium bubble, but some others came back couple hours later
So. As i mentioned before, i am doing almost everything manually. The only machine i have is autoclave.
Do you think my problem could be on laminating?
Old 05-19-2015, 16:01   #93 (permalink)
Member: 2391091
LCD 01 is a Moto G
I had also a Problem like that. After I changed my OCA the bubbles where gone.
Old 05-19-2015, 16:54   #94 (permalink)
Member: 2384272
I am using mitsubishi. What oca you was using before and whatyou using now?
Old 05-19-2015, 17:22   #95 (permalink)
Member: 2391091
I am using the same like you :-/
The Following User Says Thank You to waqas1988 For This Useful Post:
Old 05-19-2015, 20:46   #96 (permalink)
Member: 2384272
Cellularman89, where did you buy your machines. Do you have the contact?
Old 05-20-2015, 21:48   #97 (permalink)
Member: 2391091
Hello Fun!
I have the KO NO1 machine seperat and the Autoclave seperat...is that all in one Machine better? Do you have bubbles or problems like that?
And how many LCDs can you put in the built in Autoclave?
Old 05-21-2015, 03:24   #98 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Originally Posted by waqas1988 View Post
Hello Fun!
There is no difference, separate or in one. You can place up to 10 screens in to it.
Old 05-21-2015, 21:36   #99 (permalink)
Member: 523004
but with this machine, bubbles back later?
Old 05-22-2015, 10:14   #100 (permalink)
Member: 523004
please respond heI also want to buy machine 5 to 1, but then if bubbles appear, do not buy you 'lp,
Old 05-23-2015, 14:30   #101 (permalink)
Member: 523004
this machine also makes bubbles return?
Old 05-25-2015, 18:19   #102 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
The bubbles come back not depend on the machine you gonna use.
Old 05-26-2015, 22:48   #103 (permalink)
Member: 523004
please can you tell me the complete procedure for bubbles not return for pleasure
Old 06-05-2015, 18:06   #104 (permalink)
Member: 164613
Thanks Meter: 11
Hi all!
I encountered the same problem from last week (some little bubbles the next day to rework) but I still can't understand what causes them... I'm using the same machines, the same OCAs (Mitsubishi), the same chemistry for cleaning, the same compressor and so on.
The onliest criteria that changed is the temperature otside and, normally, inside...
Does there matters the air quality and humidity? (seen that somebody sais to bake the OCA before using to get out the possible moisture) but I don't use the clean room and did not use before.
I don't have an autoclave, but before there was no bubbles so I don't think this would be the problem.
About the machines like "5 in 1"- guys, that kind of machines DOES NOT WORK!!!
If you want to do a good job, you MUST have an apparatus for only one procedure.
Even in electronics there is an axioma- Less complicated is the device, it better works!
Also, I'm very sceptic about the kn6.2 films.
One man told me that the bubbles depends from the compressor power, the autoclave pressure, the temperature and operating time.
I already made a lot of tries, but it seems that will have to do a lot more.
Old 06-09-2015, 21:14   #105 (permalink)
Member: 2204208
Thanks Meter: 2
any one solve it for 100%??
Page generated in 0.25143 seconds with 8 queries
