LCD Refurbish All things related to LCD / Screen refurbish and repair |
07-17-2015, 14:02 | #122 (permalink) |
Insane Poster Join Date: Jan 2011 Location: Romania Age: 34
Member: 1499154 Status: Offline Thanks Meter: 0 | I dont trust the integrated ones, and i believe i will buy a more manual one like this one: https://www.will-hi.com/vacuum-oca-l...g-machine.html and a separate autoclave. Maybe if you put a better quality pneumatic driver then the laminating is better. |
07-17-2015, 15:40 | #123 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 360958 Status: Offline Thanks Meter: 5 | Hello, i have Triangel 5 in 1 oca machine. It is ok, the door look cheap but it do the job. The main thing for get rid of bubble is to clean it propper. In some cases i have a little scrach but still no boubble. If you have small boubble put it again in autoclave but lower the temp for 5 C. I usualy put lcd after i see there is no boubble in UV lamp. I know that the OCA glue is not UV sensitive but i still do and boubble do not come back. Also one trick if you cannot get rid of boubbles is to put a clothes peg to give a little pressure on that spot. |
07-18-2015, 16:06 | #124 (permalink) |
Insane Poster Join Date: Feb 2008 Location: Poland Gdańsk
Member: 713830 Status: Offline Sonork: 100.1656182 Thanks Meter: 28 | Always bubbles ater oca repair Anybody solve it ? 100% anybody can help I try other oca other machines other cofigurate and still have got a problem. Anybody can help ?? |
07-19-2015, 01:24 | #126 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2423658 Status: Offline Thanks Meter: 2 | I'm having problem tiny bubbles appear in the screens - mainly on top horizontal. I had the screens put into freezer straight after autoclave, bubbles appears after a few days in room temperature. |
07-19-2015, 23:10 | #128 (permalink) |
Member: 2423658 Status: Offline Thanks Meter: 2 | Im refurbiahing IP 4, 5, 6, 6+ and s4. I have a small clean room cabinet for applying oca on to lcd screen. Autoclave set on 60c and run and for 23mins with 0.7mpa. Ive done many testing using variety of base using lcd lamination press machine, diff moulds, diff oca, etc. Tinny bubbles will still reappear. |
07-20-2015, 09:54 | #129 (permalink) | |
Member: 1499154 Status: Offline Thanks Meter: 0 | Quote:
There are some like Sony Z3 and Z2 where the front glass is also the touch panel, can you replace using this machines? | |
07-20-2015, 23:41 | #133 (permalink) | |
Insane Poster Join Date: Mar 2014
Member: 2146354 Status: Offline Thanks Meter: 21 | Quote:
Okay I have spoke to many people about bubble problems and here is my conclusion. There are many reason why bubble are happening. Everybody has to find their unique problem. Some may be due to poor machinery, or poor quality or bad operation of tools/products/machines. ------------------------------------------------------------------- Here was my main problem I wasn't laying oca on the glass right. How I fixed it. make sure when you lay oca on the glass you lay it perfect with no bubbles or else you will likely have some. After you lay oca on the glass, put the glass in the autoclave for 1 full cycle. Just the glass. After autoclave session most likely you will not see bubbless on the glass, wait 30-40 mins after full cycle. Then inspect each glass individually and see if bubble reappear on glass only. The glass with no bubbles reappearing it should be good. The ones with bubbles coming back peel oca then reapply then redo cycle. See bubbles can appear from between oca and glass OR bubbles can appear from oca to lcd. '-------------------------------- My main problem was with bubblew appearing in between oca to glass You have to inspect your bubbles to see where they are forming. Use a microscope to inspect Hope this helps | |
