Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 11-23-2015, 20:07   #166 (permalink)
Member: 2400293
I stopped doing OCA and went back to LOCA. so much better results,no dust,less headache.
these chinese laminator and autoclave are not good enough. commercial factories have controlled conditions and precise industrial equipment. for small shops, its hit or miss. sometimes you get 10/10, sometimes you get 1/10. there are just so many variables to get a perfect lcd, and a lot of these variables cannot be controlled by you (such as oca moisture,grade,age or air quality on a particular day,etc..).
Old 11-27-2015, 22:27   #167 (permalink)
Member: 2489553
after all process, in vacum oven, make 25 degree. do not use over this degree. then there is no bubbles appearing on LCD
Old 12-05-2015, 08:30   #168 (permalink)
Member: 2489286
This is correct guys there is no such method for non factory oca repair I've spent thousands on machines to do this with various results in an uncontrolled environment. Don't waste your money on this Chinesse marketing plan cause you will only meet the same fate as everyone in this thread.
Old 12-07-2015, 17:32   #169 (permalink)
Member: 2245338
Thanks Meter: 4
I just donīt get the idea of why having a WhatsApp / Skype group, having this forum... Do Iīm missing something?
Old 12-14-2015, 10:39   #170 (permalink)
Member: 2330207
Hi anyone know a liquid or spray good for remove oca/loca and glue under polarized?? tnks
Old 12-15-2015, 03:31   #171 (permalink)
Member: 2500972
Try using Goo Gone. Hope that helps
Old 12-16-2015, 11:53   #172 (permalink)
Member: 2330207
Hi anyone can help me to made a cleanroom?? tnks
Old 01-04-2016, 23:24   #173 (permalink)
Member: 1218061
Hello,
I repair with LOCA and now I need work with OCA. Can you help me please choose good machines? I will buy:
1. laminating machine
Built-in Vacuum Pump LCD OCA Laminating Machine Universal OCA Laminator For iPhone Samsung LCD Touch Screen Repair
2. Second laminating machine - IS IT IMPORTANT??????
New Arrival OCA Vacuum Laminating Machine Refurbish Repair OCA Laminator LCD Lamination Machine
3. Autoclave
Black Mini High Pressure Autoclave OCA Adhesive Sticker LCD Bubble Remove Machine for Glass Refurbishment
Is it important have all these machine? Can I work without anything from these machines?
Thank you
Old 01-09-2016, 19:36   #174 (permalink)
Member: 505980
Thanks Meter: 10
Where i can buy broken glass displays???
Old 01-14-2016, 21:29   #175 (permalink)
Member: 1570234
http://forum.gsmhosting.com/vbb/f631...epair-2032841/
Old 01-19-2016, 22:24   #176 (permalink)
Member: 2245338
Thanks Meter: 4
Originally Posted by Stoyan View Post
can you add me, refurbish screens almost 3 years before +359789963393
Hi,
Iīm having an issue refurbishing iPhone 6 & 6+ screens, if I change the polarized film, the touchscreen *****, or donīt work, or works with flaws.
Iīm also putting the conductive paste in the upper corners... but no idea why this happen.
If I donīt change the polarized film, no problems at all, all working excellent, so itīs not the glass ond OCA.
If you have an advice, would be great.
Thanks
Old 01-20-2016, 11:00   #177 (permalink)
Member: 40263
Thanks Meter: 14
Hi!
I handle the adhesive Oca display .
Average 20 will be 1 piece bubble .
I do not use the machine only Remove Bubble Machine.
sorry for my bad english
The Following User Says Thank You to Lazy2003 For This Useful Post:
Old 01-21-2016, 05:06   #178 (permalink)
Member: 2518271
can you add me, refurbish screens almost 3 years before +35978%€Ģ%_€393
Hi,
Thanks
Hi, I think your problem are the Polarizer you're using in the moment!
Try to get good quality polarizer! ��
The Following User Says Thank You to hitecnology For This Useful Post:
Old 01-21-2016, 12:10   #179 (permalink)
Member: 2245338
Thanks Meter: 4
Thank you!
I ask my supplier several times, always tell me it is Original, and so on...
try different supplier, same results, also indicate it is Original Polarized film...
Do you have a link to a good polarized film so I can buy to try?
Thanks!
Old 01-21-2016, 14:22   #180 (permalink)
Member: 2518271
I've got a contact that you kann get them!
Just look at my number and write me a message and I will sent you the contact!
Page generated in 0.22264 seconds with 8 queries
