LCD Refurbish All things related to LCD / Screen refurbish and repair |
08-09-2016, 07:09 | #196 (permalink) |
Junior Member Join Date: Apr 2006 Location: Viet Nam
Member: 257372 Status: Offline Thanks Meter: 0 | This is my experience : - Apply OCA sheet on LCD of polarized area . - Do not press on screen after laminate . - Temperature of bubble remove machine depent of time , ex : 65 degree in 5 minus , pressure 4kg/cm2 I don have bubble any more . |
10-05-2016, 15:45 | #198 (permalink) | |
Junior Member Join Date: Apr 2013
Member: 1925555 Status: Offline Thanks Meter: 6 | Quote:
10-11-2016, 01:27 | #199 (permalink) | |
10-13-2016, 22:03 | #201 (permalink) | |
Trust my, the Chinese has a good design but merchandise never has a good quality. After 2 years there are a lot of new model out there and cost more than thousand dollars. If I need another marchine, I will not buy a new one and not combo all in one any more.... I suggest if you are handy just buy a old model and single stage. You just need 2 marchines : wax-bonding (laminate) and bubbling removal, those I think will less than a thousand - then buy a compressure and vacuum pump about $300 max then you will have your quality marchine fix as you need. When you have separate compresure/vacuum it can help you do more things then a build in. I don't have clean room (build a clean room for refurb LCD is a crazy idea because it cost more than 30,000 dollars in US), I just designed my own box call glove box to free particle (count smaller than dust) when I install glass on LCD panel inside my glove box, the vacuum is not only for bubbling removal, it also is helping my glove box with particle free. My 21 gallon compresure also do more job then bonding glass on LCD, it use for cleanning, automotive repairing and house painting... If you are going to do business with this LCD refurb, just build your own with single stage of marchine, not by 3 or 5 or all in 1 not save you money and made more trouble for you after few weeks. | |
The Following 3 Users Say Thank You to emvp For This Useful Post: |
12-16-2016, 14:43 | #202 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2661594 Status: Offline Thanks Meter: 0 | Pressing on the glass was probably the main reason for the bubble return! If it comes back to haunt you later down the road try throwing it back in the heat plate for 5-min (this will make the bubbles even bigger don't let that concern you.) then put straight into the auto clave for another 20min and the bubbles should be gone for good |
12-19-2016, 14:48 | #203 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i m using mitshubishi oca professional laminator machine took only 26 second big bubble remover 45c and 15 minuts even on 6s+ all is well |
12-19-2016, 17:52 | #205 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | wrong i make full videos off my machine pm for links........... |
The Following User Says Thank You to chand_gee For This Useful Post: |
01-13-2017, 00:48 | #208 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | |
01-13-2017, 14:41 | #209 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1738539 Status: Offline Thanks Meter: 11 | I worked in one of the biggest display/touch factories in China. And right now ,I run Universal Display. And it is normal that the bubble existed on certain percentage of the display or touch after the adhesive process . In the factory,we use one special machine the drive the bubble out. If anyone need, I might be able to convince some factory to do the process professionly for you. Please note it. |
The Following User Says Thank You to daneremail For This Useful Post: |
01-23-2017, 08:47 | #210 (permalink) |
Junior Member Join Date: Feb 2014 Location: peshawar kpk pakistan Age: 54
Member: 2135622 Status: Offline Thanks Meter: 0 | oca bubles comes after some time bubles comes after some time due to machine because there are machine in market which efficiency is not good to do lcd limination with accuracy. so i suggest to all foram memeber to purchase machine from certified factory. so post your problem with your machine picture that which machine was using Last edited by faizi_khalid1; 01-23-2017 at 08:55. |
