12-07-2018, 00:14 | #16 (permalink) | |
Junior Member Join Date: Jan 2011
Member: 1499837 Status: Offline Thanks Meter: 0 | Quote:
My computer doesn’t turn on at all now.Chip is blank I think. The only way I get to connect the spi adapter now is just by connecting and immediately operation on software Write file goes fine while checking gives error If I try to repeat the operation it doesn’t connect anymore so I have to remove the adapter again. When it check for erase the chip it doesn’t take time and goes to write it. This makes me think the chip is empty. I’ve tried to write the file I saved multiple times. I sent photo and file by email days ago | |
12-07-2018, 00:39 | #17 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Ok, But also try with the 1.9.4F, I'm curious if it will pass the blank check or not. I will check the emails and will go hunting for a donor file compatible with your mac also. Check the PM |
12-07-2018, 14:12 | #19 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, The file we sent you tailored to your mac, it should retain your current SN, should have no firmware lock , or iCloud account/lock on it. If the write still fails, read this thread and try like in this post from luistobcn http://forum.gsmhosting.com/vbb/f101.../#post12945915 (Yes, i know, we always suggest the computer to be in sleep mode or even turned off... but hey...if it works it works ) If this helps you give him a thanks! Best regards, HDBOX Support Team. |
