06-05-2017, 14:16 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | How to set iCloud Mode Box Setting iCloud Mode box require wait X from X minutes. In which mode i can set this time? |
06-05-2017, 16:00 | #2 (permalink) | |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Quote:
Have you already received the box? And thanks for you question. It will guide others. Q: In iCloud Mode box need sensor light cable? A: We can confirm that for iCloud mode, iCloud Fast, and EFI Lock the sensor cable is totally not required, and our users can use HDBOX to remove iCloud & EFI locks without using sensor cable. Q: Setting iCloud Mode box require wait X from X minutes. In which mode i can set this time? A: This values are required for normal iCloud removal, and these options give you the power to synchronize the iCloud unlocking process with the mac if mac is displaying any waiting messages. If no code was tested on that mac, 0 out of 0 it is the perfect choice, but if instead you tested the iCloud fast method support you can set it to wait 5 from 5 minutes. The method to test for iCloud fast support is: to enter 5 codes by hand, wait 1 minute, then enter 6th code, and when computer display wait 5 minutes you restart the mac. If upon reboot mac is allowing you to enter again 5 codes fast, with no delay between them, then iCloud fast method is supported. But, if upon reboot mac is displaying on screen “Wait 5 minutes” you can use “Wait 5 out of 5 minutes” and the box will wait 5 minutes before entering the first code, and be in sync with the mac, and you do not have to wait 5 minutes + 10 minutes + 15 minutes to perform a manual sync. Please note it. Thanks HDB TEAM | |
06-05-2017, 19:41 | #6 (permalink) |
Member: 329458 Status: Offline Thanks Meter: 153 | Sir, macbook air 2012 have 4 digits pin lock and firmware password. There is a possibility that pin and password are same? Because in efi mode i can bruteforce it in less time than iCloud or iCloud fast |
06-06-2017, 06:39 | #7 (permalink) | |
Yes. Exactly this is why we reconmend find iCloud password by using EFI firmware password screen. If brute forcing 4 digit code via icloud screen takes about 1 week, and by using firmware password takes about 2 days. | |
