10-06-2017, 19:54 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Guangzhou, China
Member: 659181 Status: Offline Thanks Meter: 7,652 | IPhone 7 / Iphone7 plus unlocking supported! Update : IPhone APP 3.0D released - ADDED: Ability to use HDBOX manager to activated iphone 7 functionality without entering the code in HDBOX. This feature will be part of the next release of HDBOX Manager Software, - HOTFIX1: Activating iPhone 7 functionality without restarting the app. Issue: When you activate iphone 7 functionality, HDBOX will keep asking you the activation code more than one time when trying to use it, the fix was a simple restart of the iPhone APP or of the HDBOX itself in order to allow the iPhone APP to read the activation from storage, - HOTFIX2: During Setup Process if user press confirm after adjusting sensor delta value it will be saved. Issue: When you adjust the sensor delta during the setup process and press confirm to quickly end the setup process the new values for sensor delta & sensor detection type were not saved. The fix was to use enter key until whole setup process was completed and then settings were saved. - Tweak: HDBOX text-to-speech engine can properly handle IOS version 10 & 11 now - Tweak: Is related with HotFix2, The sensor module now have a hard check it's sensor settings to be in valid ranges: 5% to 100% for relative mode ( default is 20% ) 5+- to 127+- for absolute mode ( default is 20+- ) More Info Click Here Best regards, HDBOX Support Team. |
