Old 08-11-2022, 17:30   #1 (permalink)
Member: 1038150
Thanks Meter: 45
6s+ 7+ 8 plus backup passcode %45 failed try agin problem fix please team
Checking iDevices.....OK
Checking SSH......OK
Waiting for server.....OK
Activation Files Backing up .......Failed! Try Again
Operation {Backup Passcode IOS 11.x Up 15.x} ID: 43FDE67C52B8DE81
Elapsed time 00:19 -- Version 4.3.6
The Following 2 Users Say Thank You to blackie06 For This Useful Post:
Old 08-13-2022, 09:50   #2 (permalink)
Thanks Meter: 21,231
bypass passcode With Signal IOS 15....x
https://www.youtube.com/watch?v=Mqxr...nel=calmsystem
Old 08-13-2022, 12:25   #3 (permalink)
Member: 1038150
Thanks Meter: 45
I know the method, I have made a lot of phones, but for the last 1 week, it gives this problem on all models.
Old 08-13-2022, 14:54   #4 (permalink)
Sir, this error has been bypassed icloud previously not supported
Old 08-13-2022, 17:40   #5 (permalink)
Member: 1038150
Thanks Meter: 45
no it was never done before i did it for the first time
Old 08-13-2022, 17:40   #6 (permalink)
Member: 1038150
Thanks Meter: 45
No, I'm dealing with these phones for the first time bro.
no one else looked at them.
Old 08-16-2022, 19:04   #7 (permalink)
Member: 1038150
Thanks Meter: 45
It gives the same error on untested phones, the server may be problematic.
Old 08-18-2022, 09:45   #8 (permalink)
I sent a problem to the technical department, it will be followed up and fixed
Old 08-22-2022, 16:21   #9 (permalink)
kamraankisskiss's Avatar
Member: 1261180
Sonork: 100.1590645
Thanks Meter: 97
flash retain userdata with 3utool then try.i think your problem will be solved.
Old 08-22-2022, 20:48   #10 (permalink)
Member: 2779917
Thanks Meter: 87
Yes i have fixed a i7 plus it stock at 25% after update lates ios in 3utool bypassed done, note, select retain user data in the 3utool
Old 08-23-2022, 00:14   #11 (permalink)
Crazy Poster
Member: 587029
Thanks Meter: 8
Same problem iphone 7+
I get the same error when do backup passcode. Iphone 7 plus IOS 15.6.1
Old 08-23-2022, 09:18   #12 (permalink)
error 45% not supported sir
Old 09-27-2022, 04:17   #13 (permalink)
Member: 67240
Thanks Meter: 45
allways problems
this software always have problems, always a new problem, worst than my wife...
The Following User Says Thank You to enrocas For This Useful Post:
Old 09-28-2022, 08:53   #14 (permalink)
These are problems from your computers and error definitions that work perfectly
Old 12-15-2022, 05:29   #15 (permalink)
Member: 1285139
Thanks Meter: 181
Can you explain what is Problem with Our PC
Page generated in 0.21957 seconds with 8 queries
