05-21-2020, 18:18 | #61 (permalink) |
Major Poster Join Date: Apr 2016 Location: colombia Age: 33
Member: 2559017 Status: Offline Thanks Meter: 3 | help!!!! I recently bought the eft pro license, but at any moment the error that I leave below appears to me. I was using it on two computers and only one is working for me, could you help me by activating it to use it on both computers ----------------------------------------------------------------- español buenas tardes. compre hace poco la licencia de eft pro, pero de un momento a otro me aparece el error qu dejo acontinuación. la estaba utilizando en dos computadores y solo en uno me esta funcionando, me podrian ayudar activando para utilizarla en los dos computadores. --------------------------------------------------------------------- |
05-24-2020, 12:31 | #62 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Would it be possible to add an option to enable adbd in insecure mode so you don't have to pair it with PC, much like with eng-root files? |
05-26-2020, 03:50 | #63 (permalink) |
Member: 2559017 Status: Offline Thanks Meter: 3 | I have not managed to make an a305g, in models j200m, j260m bit 6- bit10, g570m bit1,2,3,4,5,6,7, j700m, everything is perfect. no he logrado hacer un a305g, en modelos j200m, j260m bit 6- bit10, g570m bit1,2,3,4,5,6,7, j700m, todo salen perfecto. |
06-09-2020, 02:51 | #64 (permalink) |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | ROOT SM-J250F problem hi i have make root for the phone from the ap file correctlly and flashed it in eft file section and i have some root premition but some of the apps doen not work but when i am flashing it again whole firmware the app works well |
06-29-2020, 03:06 | #65 (permalink) |
Member: 2496790 Status: Offline Thanks Meter: 11 | HI. I have tryed to root samsung sm-a107f it has mtk mt6762 and i think i have hard brick it ! so my question why is this thing happens and does eft pro support this model for rooting ? can i try again ? |
06-30-2020, 00:12 | #67 (permalink) |
Member: 2496790 Status: Offline Thanks Meter: 11 | Thank you for the answer but... opps i cause you to loose new device it is not nice to hear that . 1. can you ,pls, let me became wiser by telling how could i knew that before i have done it ? 2. all or most of the videos tutorials says " rooting all samsung devices" 3. pls tell me what or were can i read all the pros & cons about rooting in the eft method so i will not hard brick another device 4. Can you help me some guide lines how to unbrick it ( not jtag involved) 5. does all mtk devices not support this method ? or only some of the mtk's have secure boot ? 6. button line i understand so no hard fillings thanks |
07-09-2020, 19:06 | #68 (permalink) |
Freak Poster Join Date: Aug 2002 Location: ndakaru
Member: 14880 Status: Online Thanks Meter: 16 | Can't root 2020-07-09_20h01_31.jpgsm-a515f root error |
07-15-2020, 01:33 | #69 (permalink) | |
Member: 2496790 Status: Offline Thanks Meter: 11 | Quote:
08-02-2020, 10:55 | #71 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Among all Samsung devices Only locked bootloader devices are not supported , and how to knowif locked , it depends on experience or search google . btw locked bootloader device doesnt accept the root kernel so it will not be flashed or cause hard brick . A10s hard brick is caused by partially flashing different BL and Boot from another Android version , even if same binary in this device it is not safe . example : A10 S android 9 bianry 3 you cannot flash only BL or Boot from android 10 bianry 3 it will hard brick and same for downgrade.. You MUST full flash device not partially flashed |
The Following User Says Thank You to easy-team For This Useful Post: |
08-03-2020, 00:59 | #72 (permalink) | |
ofcourse about the downgrae this is not the case i did not downgrade it so maybe as you said about the lock bootloader i just want to understand pls i ofcourse unlocked it as "google" said so why it need to hard bricked it if there is two resons to that and none of them i have done! so if i understood all new devices that need to unlock the bootloder first can not be rooted by the EFT BOX ? and regardless the issue here ! there is a way to downgrade devices so.. such as unlocking the bootloder , is that right ? Last edited by GODISTHEBEST; 08-03-2020 at 01:05. | |
