Old 11-02-2023, 23:03   #1 (permalink)
Thanks Meter: 20,608
EFT Pro Dongle Update V4.5.9 Added New Remove Icloud Open Menu BY APPLE ID
EFT Pro Dongle Update V4.5.8 Build 001 is released :
What's New :
[Apple]
Proxy Server: 144.76.176.118
Port: 8888
144.76.176.118:8888
Fix BOOT Purple Mode (Serial Changed)
Added New Boot iOS 17
iPad Pro (12.9inch)(2nd generation) (WiFi) iPad7,1j120ap
iPad Pro (12.9inch)(2nd generation) (Cellular) iPad7,2j121ap
iPad Pro (10.5inch)(WiFi) iPad7,3j207ap
iPad Pro (10.5inch) (Cellular) iPad7,4j208ap
iPad (6th generation)(WiFi) iPad7,5j71bap
iPad (6th generation)(Cellular) iPad7,6j72bap
iPad (7th generation)(WiFi) iPad7,11j171ap
iPad (7th generation)(Cellular) iPad7,12j172ap
[QUALCOMM]
Added New Write Flash For Qualcomm Devices
Added Write Flash XML File
Added Write Flash HUAWEI Firmware
Added Write Flash SAMSUNG Firmware
Added Write Flash OPPO/REALME Firmware
Added EMMC DATA
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 18 Users Say Thank You to easy-team For This Useful Post:
Old 11-03-2023, 00:29   #2 (permalink)
Member: 2666112
Thanks Meter: 88
emmc data for waht is??????
Old 11-03-2023, 04:21   #3 (permalink)
Member: 1766019
Thanks Meter: 19
support spd nokia 4g. please!!!
Old 11-03-2023, 05:58   #4 (permalink)
Member: 2143310
Thanks Meter: 33
pls team add read flash spd
Old 11-03-2023, 06:42   #5 (permalink)
Member: 2383501
Sonork: 100.1660513
Thanks Meter: 189
Thanks Best Team For Best Support
Old 11-03-2023, 08:41   #6 (permalink)
Member: 908095
Thanks Meter: 7
good update thanks ....
Old 11-03-2023, 09:03   #7 (permalink)
Member: 1872250
Thanks Meter: 33
ios 17 ipad 7th gen still not working boot ramdisk
Old 11-03-2023, 12:11   #8 (permalink)
XxTQxX's Avatar
Member: 1068286
Thanks Meter: 181
The big boss is Here !
Thank you Team keep it up
Old 11-03-2023, 12:45   #9 (permalink)
Member: 3041584
Sonork: Ok
Old 11-03-2023, 15:32   #10 (permalink)
unlock_allgsm's Avatar
Member: 1678945
Sonork: 100.1620753
Thanks Meter: 107
Old 11-03-2023, 21:03   #11 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 532
Always good update..............
Old 11-04-2023, 04:18   #12 (permalink)
Member: 2353766
Thanks Meter: 61
thanks for nice update team
Old 11-04-2023, 06:14   #13 (permalink)
Member: 1503859
Sonork: 100.1672251
Thanks Meter: 42
good work Eft Pro team...
Old 11-04-2023, 08:12   #14 (permalink)
alyas_ashiq's Avatar
Member: 1112242
Sonork: 100.1617813
Thanks Meter: 126
Heloo EFT I see New Setting In Log
Adress : 144.76.176.118 Port: 8889
But You Mention Adress : 144.76.176.118 Port: 8888
Old 11-04-2023, 09:56   #15 (permalink)
The port number and address may change and you can find the new data when you register a new request attached to the iCloud account and press start in the open menu list
Page generated in 0.11380 seconds with 8 queries
