02-25-2024, 23:29 | #1 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,313 | EFT Pro Dongle Update V4.6.8 is released (Remove Icloud Open Menu with UDIDl FMI OFF) EFT Pro Dongle Update V4.6.8 Build 001 is released : What's New : [APPLE] Added Remove Icloud Open Menu with UDID (FMI OFF with UDID)Free Exclusive
Previous Version EFT Pro Dongle Feature [MTK] Kind Regards, Easy Firmware Team Get Now EFT Dongle From Nearest Distrubutor/Reseller Here EFT Tool Pro WithoutDongle Last edited by easy-team; 02-25-2024 at 23:52. |
The Following 19 Users Say Thank You to easy-team For This Useful Post: |
02-26-2024, 01:00 | #2 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hello good update, but, I think you must protect this info, Quote:
The Following 2 Users Say Thank You to Shensohau For This Useful Post: |
02-26-2024, 07:46 | #6 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | iam done all steps but sw give me this error Code: Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .....(a79c2d7d78490cb566ea8f680a0629cb1c9f3fdc)... ERROR: DATA NOT FOUND OR TOKEN EXPIRED Please follow the instructions below and try again: 1 - Before connecting the DEVICE WITH ICLOUD to the WIFI network go to the wifi settings and configure Proxy Server: 51.178.81.232 Port:8882 press Save, and then connect 2 - Go from safari to "51.178.81.232:8882" and press download , then Allow 3 - Go to Settings General->Profile and Install the profile you downloaded 4 - Then go Settings->General->About-> scroll down and after go to Certificate Trust Settings and enable DO_NOT_TRUST 5 - Go to iCloud > Turn OFF Game Center->Then Turn ON again (only 1 times) 6-After completing the previous steps, go apple Tap select (Remove Icloud Open Menu with UDID (FMI OFF with UDID)) and click Start again go to icloud turn on and off game center If the process is successful, Turn OFF WiFi then check iCloud services before flashing. Operation {Remove Icloud Open Menu with UDID} ID: 1E98C972F1960EC8 Elapsed time 00:02 -- Version 4.6.8 Build 002 |
02-26-2024, 07:49 | #7 (permalink) | |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,313 | Quote:
The Following User Says Thank You to easy-team For This Useful Post: |
02-26-2024, 07:54 | #8 (permalink) |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | I did everything as asked by the program, entered the proxy server address and the port set the certificate to trusted I turned off and turned on the game center and tried to do fmi off in the software. but the result is the same as in the log above. |
The Following User Says Thank You to UzUnlocker For This Useful Post: |
02-26-2024, 10:17 | #13 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,780 | Waiting for server.....OK Checking iDevices.....OK Remove icloud with UDID .....(00008103-000579D12E30C01E)... Model:iPad Air (5th generation) Device Name:iPad MODE:CLEAN Status:OFFLINE Status Code:200 Removed:Success ✅ ======================== Operation {Remove Icloud Open Menu with UDID} ID: D26B1267B9B5FC85 Elapsed time 00:05 -- Version 4.6.8 Build 002 |
The Following 3 Users Say Thank You to MARVZ_TG For This Useful Post: |
