05-11-2021, 17:39 | #91 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2252284 Status: Offline Thanks Meter: 12 | IOS Version: 14.5 SIM Status: kCTSIMSupportSIMStatusReady MEID Status: Not Supported Preparing.....OK Bypassing.....Failed Operation {Bypass iCloud at Hello Screen} ID: 495D027F66E4A49E Elapsed time 01:04 -- Version 4.0.0 |
05-11-2021, 18:09 | #92 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Earth
Member: 2620603 Status: Offline Thanks Meter: 40 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.102.4 Device IMEI: 359216********* Product Name: iPhone OS Product Type: iPhone 7 Plus IOS Version: 14.5.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2M********* MEID Status: Not Supported Preparing.....OK Bypassing.....Failed Operation {Bypass iCloud at Hello Screen} ID: 9F61561562D35EAB Elapsed time 01:17 -- Version 4.0.0 |
The Following User Says Thank You to red5ive For This Useful Post: |
05-11-2021, 20:14 | #94 (permalink) |
No Life Poster Join Date: Sep 2002 Location: south Afrika Age: 38
Member: 15156 Status: Offline Thanks Meter: 73 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.102.4 Device IMEI: 356765083061661 Product Name: iPhone OS Product Type: iPhone 8 IOS Version: 14.5.1 SIM Status: kCTSIMSupportSIMStatusPINLocked Device Serial Number: C7CVFHELJC69 MEID Status: Not Supported Preparing.....OK Bypassing.....Failed Operation {Bypass iCloud at Hello Screen} ID: 08900CCE32D5B94A Elapsed time 01:10 -- Version 4.0.0 stop at 20percent |
The Following User Says Thank You to osmanabu For This Useful Post: |
05-11-2021, 20:59 | #97 (permalink) |
Junior Member Join Date: Jul 2017 Age: 37
Member: 2742347 Status: Offline Thanks Meter: 1 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-6723.102.4 Device IMEI: 358684092515039 Product Name: iPhone OS Product Type: iPhone 7 IOS Version: 14.5.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: DV6YT0Q0HG7J MEID Status: Not Supported Preparing.....OK Bypassing.....Failed Operation {Bypass iCloud at Hello Screen} ID: 2992839233C3F71C Elapsed time 01:09 -- Version 4.0.0 |
05-11-2021, 22:51 | #99 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2161502 Status: Offline Thanks Meter: 0 | hello guys i need help with my iphone 6 it keeps failing..i need help Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.270.14 Device IMEI: 352075068284328 Device MEID: 35207506828432 Product Name: iPhone OS Product Type: iPhone 6 IOS Version: 12.5.3 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: DNPNGHB3G5MR MEID Status: Supported Preparing.....OK Bypassing.....Failed Operation {Bypass iCloud at Hello Screen} ID: 52EE258FF92CB9FD Elapsed time 01:08 -- Version 4.0.0 |
05-11-2021, 23:57 | #100 (permalink) | |
Registered User Join Date: Nov 2018 Location: Europe
Member: 2877580 Status: Offline Thanks Meter: 6 | Quote:
Jailbreak with lastest Checkra1n, put a working sim card and then click bypass will work perfectly with network. I had error at 20% then used a sim card inside and did bypass and it was perfect done with network. if phone is network locked after bypass it will work perfect with network signal so just tested one iphone 7 plus at 14.5.1 for now. | |
The Following 3 Users Say Thank You to global4 For This Useful Post: |
