01-30-2021, 22:00 | #17 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: In The World
Member: 1068286 Status: Offline Thanks Meter: 182 | Quote:
Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM7} Switching to Meta Mode.....Failed: ? Operation {Factory Reset META} ID: B63073CCCADAB138 Elapsed time 00:54 -- Version 3.9.0 Here phone information : Identifying Hardware ID..... BROM CPUID : 0766 (0000)MT6765[6765] BROM HW_SW_VER : 8A00 CA00 0000 0000 Handshaking... Identifying Hardware ID..... BROM CPUID : 0766 (0000)MT6765[6765] BROM HW_SW_VER : 8A00 CA00 0000 0000 FUSEID : 00000000 SECURE VERSION : 05 BL VERSION : FE BR Secured : E7[SBC+SDA+SEL] | |
The Following User Says Thank You to XxTQxX For This Useful Post: |
01-30-2021, 22:36 | #22 (permalink) |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | i am new in eft software can give quick advice for using it? and please tell me I have OPPO F15 Pro User locked, what setting should I do (Factory Reset META (BOOT MODE) or Factory Reset META Recovery (BOOT MODE)) and secondly, do I have to check "Alternative META Switch Method" check box? |
01-30-2021, 23:10 | #25 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Cameroon
Member: 1433726 Status: Offline Sonork: 100.1644838 Thanks Meter: 106 | OPPO RENO 2Z ONE CLICK RESET DONE Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM3} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM3} Connecting to Meta port.....OK Reading info.....OK Device SDK: 29 Device data encryption: encrypted Device Hardware: mt6779 Device CPU: arm64-v8a Device Factory: OPPO Device Factory: OPPO Device Factory: OPPO Device Model: PCKM80 Android version: 10 Device Firmware: PCKM80_11_C.13 Executing Erase command.....OK - Note: if device not entered to recovery and process format automatically then - Boot to recovery manually and perform factory reset Operation {Factory Reset META Recovery} ID: DD32B57644F369D4 Elapsed time 01:01 -- Version 3.9.0 |
01-30-2021, 23:37 | #26 (permalink) | |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Quote:
Regarding our OPPO update, We added two methods, one via Boot Mode and other via Meta Mode The Meta-mode method requirs only a press on a button, as it is for device factory settings only and it is availble in MTK >> Meta Section The Boot Mode method applies on all MTK sections, You just need to Select ( exploits ) after you select which operation you need including Flash, FRP, Screen unlocking and all other features, But Notice, some devices need to add a preloader, DA and Scatter, Of course they will be already available to you if you want to flash your device. Oppo devices firmware files are in ofp format, so you must extract the firmware and get all needed files from inside . WE WILL ADD OFP EXTRACT METHOD LATER IN OUR COMING UPDATES. | |
The Following 4 Users Say Thank You to easy-team For This Useful Post: |
01-31-2021, 01:57 | #29 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | fix all operation for models which you add in previous versions, specially huawei mtk id removal,. thanks,. nice update,. Last edited by markrempillo; 01-31-2021 at 02:03. |
01-31-2021, 04:56 | #30 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Late comer but good to see mtk update finally added in eft , now expecting vivo + redmi Qualcomm support without auth in next update hope so u guys work on that |
The Following User Says Thank You to djj007 For This Useful Post: |
