Old 07-24-2020, 01:37   #16 (permalink)
Member: 421573
Sonork: 100.1650534
Thanks Meter: 54
Old 08-26-2020, 07:09   #17 (permalink)
Member: 2519102
Thanks Meter: 93
try flash multi appfile
but nolock
error
Searching for upgrade port.....Detected {COM49}
Connecting to device.....OK
Start processing file [C:/Users/LARABET/Desktop/YAL-L61 10.0.0(C636) Downgrade For FRP Bypass By EFT Pro (AOD)/A.APP] 5,15 GB:
Flashing [sha256rsa.img].....OK
Flashing [crc.img].....OK
Flashing [base_verlist.img].....OK
Flashing [base_ver.img].....Failed: Write failed
Operation {Flash multi APP files} ID: 32976B1D604A07EF
Elapsed time 00:59 -- Version 3.4.3
Old 08-28-2020, 23:15   #18 (permalink)
Thanks Meter: 21,230
Please notice that 10.1 is not supported yet .
Old 09-01-2020, 09:04   #19 (permalink)
Member: 91698
Device Model: VOG-L29
Device Firmware: :VOG-L29 10.1.0.133(C431E19R2P5)
Base Firmware: :VOG-LGRP2-OVS 10.1.0.133
Custom Firmware: :VOG-L29-CUST 10.0.0.19(C431)
Preload Firmware: :VOG-L29-PRELOAD 10.0.0.5(C431R2)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Operation {Read info} ID: 440AB9634CCF403E
Elapsed time 00:00 -- Version 3.4.3
i can't downgrade
Old 10-15-2020, 03:24   #20 (permalink)
Member: 157312
Thanks Meter: 72
We need your upgrade ... Thank you
Old 11-21-2020, 21:08   #21 (permalink)
Member: 1674096
Thanks Meter: 49
VNS-L31 reset screen lock error
Checking fastboot device.....OK
Reading info.....OK
Device Model: HUAWEI VNS-L31
Device Serial: FUH7N1670xxxxxxx
Device IMEI: 86218903xxxxxxxx
Device Firmware: :VNS-L31C636B503
Device Lock: locked
Waiting for server.....OK
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....Security is not supported
Operation {Reset ScreenLock} ID: 018B48E08BE7051D
Elapsed time 00:24 -- Version 3.5.0
i also tryed with temporary bootloder unlock still same error.how to bootloder unlock without data loss?i need very important data and this is android 7
Old 12-23-2020, 19:32   #22 (permalink)
Member: 626140
Thanks Meter: 2
Reading info.....OK
Device Model: BAC-L21
Device Serial: GUYDU17
Device IMEI: *********
Device IMEI2: *********
Device Firmware: :BAC-L21 8.0.0.349(C185)
Preload Firmware: :
Device Lock: locked
Reading data.....OK
Operation {Reset FRP using server} ID: CB50F7409120E8CC
Elapsed time 00:13 -- Version 3.6.1
The Following User Says Thank You to mcsc For This Useful Post:
Old 01-03-2021, 10:49   #23 (permalink)
Member: 346148
Thanks Meter: 27
add force upgrade mode
hi team
many user lost upgrade mode on huawei phone
i thnk it is time to add a way on next update to force upgrade mode
as this exist on other boxes
thks
Old 01-16-2021, 11:28   #24 (permalink)
Member: 86359
Searching for upgrade port.....Detected {COM151}
Target model [HRY-LX1T 10.0.0(C185)]
Reading data from server.....OK
Bypassing downgrade protection.....Failed: writing failed, Please contact support team
Operation {Downgrade to reset FRP} ID: 8B765CCFD73FE049
Elapsed time 00:07 -- Version 3.7.2
Old 07-19-2021, 17:47   #25 (permalink)
Member: 164253
Thanks Meter: 4
Reading info.....OK
Device Model: MAR-LX1A
Device Firmware: :MAR-L21A 10.0.0.435(C431E13R2P7)
Base Firmware: :MAR-LGRP2-OVS 10.0.0.435
Custom Firmware: :MAR-L21A-CUST 10.0.0.13(C431)
Preload Firmware: :MAR-L21A-PRELOAD 10.0.0.7(C431R2)
Device Lock: locked
Operation {Read info} ID: D2E963212DD4E230
Elapsed time 00:00 -- Version 4.0.1
Searching for upgrade port.....Detected {COM70}
Target model [MAR-L21A 10.0.0(C431)]
Operation {Downgrade to reset FRP} ID: F9CD3D4D2419E5DB
Elapsed time 00:01 -- Version 4.0.1
Old 07-20-2021, 08:56   #26 (permalink)
Member: 2921514
Thanks Meter: 19
https://forum.gsmhosting.com/vbb/f10...-help-2961805/
spent many days work, not find a solution
after write board sofware imei gone
dont find solution to flash phone with repair imei
veryvery bad experience with eft
Old 07-20-2021, 16:59   #27 (permalink)
Member: 2518179
Thanks Meter: 40
Contact me I can help you
Page generated in 0.21983 seconds with 8 queries
