10-08-2018, 01:14 | #2 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, firmware according to samsung and country model and operator and it will return to normality your samsung, before re-flashing a combination file it is very important to look at the binary, if it can not happen what has happened to you or even worse that you have what to do jtag or emmc, thanks. |
10-09-2018, 19:17 | #6 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | I think you killed it yourself. Combination name is for G930A and you flashed it to G930U. That should be the reason why it died. Think of JTAG |
10-10-2018, 16:06 | #8 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Both devices have the same combination , i think device is in Jtag mode , wait till battery drains or disassemble the device and remove the battery. |
12-13-2018, 04:02 | #9 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
I flash the "U" normal and combi onto any carrier branded S7 all the time, so that's not the issue. Just as Easy-Team said, disassemble the phone, disconnect the battery cable, hold own Home + Vol Down and while holding those 2 buttons insert the usb cable. Once you see the download screen, immediately reconnect the battery cable, and try to reflash it with the latest firmware first, then the combi. | |
