02-21-2020, 17:52 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Poland
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | How to flash DRA-L21 Y5 2018 ? Checking fastboot device.....OK Reading info.....OK Device Model: DRA-L21 Device Serial: BRE9K18B08904953 Device IMEI2: 864722044288201 Device Firmware: DRA-L21 1.0.0.149(C432) Device Lock: Check root info is safe | Lock state is lock | Root State: UNROOT Checking needed files.....Not found Writing rescue image.....Failed: Flashing failed Operation {Flash APP Firmware} ID: 76E1529BDC8BDF9E Elapsed time 00:25 -- Version 1.9.4 and TRY Flash APP Firmware (Fastboot): Checking fastboot device.....OK Reading info.....OK Device Model: DRA-L21 Device Serial: BRE9K18B08904953 Device IMEI2: 864722044288201 Device Firmware: DRA-L21 1.0.0.149(C432) Device Lock: Check root info is safe | Lock state is lock | Root State: UNROOT Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....Security is not supported Operation {Flash APP Firmware} ID: 7E47FDC37A3A6B0E Elapsed time 00:19 -- Version 1.9.4 Any help? |
02-22-2020, 21:47 | #3 (permalink) |
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | I have this file, and ver 150 and 155, but flashing error. I many flashed huawei with EFT on Kirin but this phone on MTK and show errors on all flash option... |
02-24-2020, 15:09 | #4 (permalink) |
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | On flash with scatter file with MTK tab show error: Setting up.....OK Loading files.....OK Waiting for MTK port.....Detected {COM17} Connecting to Brom.....Failed: STATUS_SEC_AUTH_FILE_NEEDED Operation {Flash firmware} ID: 2F6E55B4B2DE853A Elapsed time 00:08 -- Version 1.9.4 Any help? |
02-25-2020, 06:33 | #5 (permalink) |
Freak Poster Join Date: Apr 2019 Location: Egypt Age: 25
Member: 2906511 Status: Offline Thanks Meter: 136 | if your device can enter upgrade mode then you can use EFT to flash it ,just follow the guide : 1-power of your phone and press and hold volume up and volume down and insert usb cable 2-open eft and go to huawei tab and choose flash firmware (upgrade mode ) 3-select your firmware and press start good luck |
