Old 11-07-2017, 16:26   #1 (permalink)
Ahmed Zitoon's Avatar
Member: 187853
Sonork: 100.1609563
Thanks Meter: 1,207
How to Reset FRP for Motorala Qualcomm Using EFT Dongle including Nexus 6
Dear Valuable Clients
Steps For Nexus 6 Remove FRP
1- Connect Phone To FastBoot Mode
2- Use Method 2 For FRP
3- Some Of Build Get Bootloop ,
4- Now Move To Bootloop Fix And Click On Button
5- Now Phone Will Power On On Home Screen And Boot Normally
6- You Can Move To App Manger And Click On Reset FRP Button
- Or U Can Do Step 2 Again ( Use Method 2 For FRP ) -
7- One You See Phone Go To Home Screen Please
  • During Any Frp Processing Task You Get Your Nexus Reboot Always Or Stuck On Fastboot Mode Or Bootloop , You Have To Click On Bootloop Button
Go
Enable developer option, enable oem unlock & usb debugging. Then do factory reset. if you cant bypass to screen Please enter recovery mode to wipe data & cache after doing factory reset !
Steps For Motorala New Build Remove FRP NewSecurity
2- Use Method 1 For FRP
3- If You Get No Call - No Network - Commserver Go To CommServer Fix And Click Button
Steps For Motorala Old Build Remove FRP Old Security
Once Phone Power One Remember To Do This Steps
br,
AhmedZitoon
The Following 25 Users Say Thank You to Ahmed Zitoon For This Useful Post:
Old 11-07-2017, 20:28   #2 (permalink)
Member: 1272411
Sonork: 100.1646094
Thanks Meter: 10
where is Now Move To Bootloop Fix And Click On Button??
Old 11-07-2017, 21:37   #3 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 712
Now that's something we have been waiting for. That's why you refused to sell han,,
Old 11-08-2017, 04:42   #4 (permalink)
Member: 1998299
Thanks Meter: 16
Thanks
Go
br,
AhmedZitoon
Excelent, Its work beautiful!!!!
The Following User Says Thank You to NCDSC For This Useful Post:
Old 11-08-2017, 04:42   #5 (permalink)
Member: 1998299
Thanks Meter: 16
Thanks
Go
br,
AhmedZitoon
Old 11-09-2017, 09:08   #6 (permalink)
IMIM@HACK99's Avatar
Member: 2688744
Thanks Meter: 166
Nice work its working 100%
The Following User Says Thank You to IMIM@HACK99 For This Useful Post:
Old 11-10-2017, 06:17   #7 (permalink)
Member: 2303399
Thanks Meter: 29
please add tab reboot to fastboot in new tab option
The Following User Says Thank You to naseer raza For This Useful Post:
Old 11-12-2017, 07:33   #8 (permalink)
Member: 2509163
Thanks Meter: 77
i can't figured out why some motorola devices get lost their networks after reset frp....???
any suggestion todo before reset frp ?
Old 11-12-2017, 13:11   #9 (permalink)
Mohammed Aamri's Avatar
Member: 2536614
Thanks Meter: 2,791
We fixed network problem before check here : EFT Dongle V1.2.5 Release MOTO FRP BOOT-LOOP FIX AND MORE 07/11/2017
BR,
Mohamed Aamri
Old 11-15-2017, 16:32   #10 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 712
nexsus 6 frp not working
INFOversion: 0.5
INFOversion-bootloader: moto-apq8084-72.04
INFOproduct: shamu
INFOboard: shamu
INFOsecure: yes
INFOhwrev: 0x83A0
INFOradio: 0x6
INFOemmc: 32GB Sandisk REV=07 PRV=01 TYPE=57
INFOram: 3072MB Hynix S8 SDRAM DIE=6Gb
INFOcpu: APQ8084 ES1.1
INFOserialno: ZX1G22GX28
INFOcid: 0x00DE
INFOchannelid: 0x00
INFOuid: A29CD40011000000000000000000
INFOunlocked: no
INFOsecurestate: locked
INFOiswarrantyvoid: yes
INFOmot_sst: 2
INFOmax-download-size: 536870912
INFOreason: Fall-through from factory boot mode
INFOimei:
INFOmeid:
INFOdate:
INFOsku:
INFOiccid:
INFOcust_md5:
INFOmax-sparse-size: 268435456
INFOcurrent-time: "Fri Nov  7  5: 3:30 UTC 2014"
INFOro.build.fingerprint: none
INFOro.build.version.full: none
INFOro.build.version.qcom: none
INFOversion-baseband: D4.01-9625-05.45+FSG-9625-02.
INFOkernel.version: none
INFOsdi.git: git=MBM-NG-V72.04-0-gf291c61
INFOsbl1.git: git=MBM-NG-V72.04-0-g60ea7e6
INFOrpm.git: git=MBM-NG-V72.04-0-g18b261e
INFOtz.git: git=MBM-NG-V72.04-0-g921699c
INFOaboot.git: git=MBM-NG-V72.04-0-gb11eacf
INFOpartition-type:modem: raw
INFOpartition-type:metadata: raw
INFOpartition-type:sbl1: raw
INFOpartition-type:sdi: raw
INFOpartition-type:sec: raw
INFOpartition-type:ddr: raw
INFOpartition-type:aboot: raw
INFOpartition-type:rpm: raw
INFOpartition-type:utags: raw
INFOpartition-type:tz: raw
INFOpartition-type:padA: raw
INFOpartition-type:sbl1bak: raw
INFOpartition-type:abootBackup: raw
INFOpartition-type:rpmBackup: raw
INFOpartition-type:utagsBackup: raw
INFOpartition-type:tzBackup: raw
INFOpartition-type:versions: raw
INFOpartition-type:frp: raw
INFOpartition-type:mdm1m9kefs1: raw
INFOpartition-type:mdm1m9kefs2: raw
INFOpartition-type:mdm1m9kefs3: raw
INFOpartition-type:padB: raw
INFOpartition-type:sp: raw
INFOpartition-type:keystore: raw
INFOpartition-type:logs: raw
INFOpartition-type:persist: raw
INFOpartition-type:mdm1hob: raw
INFOpartition-type:mdm1dhob: raw
INFOpartition-type:cid: raw
INFOpartition-type:logo: raw
INFOpartition-type:misc: raw
INFOpartition-type:padD: raw
INFOpartition-type:mdm1m9kefsc: raw
INFOpartition-type:ssd: raw
INFOpartition-type:recovery: raw
INFOpartition-type:kpan: raw
INFOpartition-type:boot: raw
INFOpartition-type:cache: ext4
INFOpartition-type:oem: raw
INFOpartition-type:padC: raw
INFOpartition-type:system: raw
INFOpartition-type:userdata: ext4
INFOpartition-size:modem: 0x0000000007000000
INFOpartition-size:metadata: 0x0000000001000000
INFOpartition-size:sbl1: 0x0000000000060000
INFOpartition-size:sdi: 0x000000000000e000
INFOpartition-size:sec: 0x0000000000004000
INFOpartition-size:ddr: 0x0000000000008000
INFOpartition-size:aboot: 0x0000000000100000
INFOpartition-size:rpm: 0x0000000000040000
INFOpartition-size:utags: 0x0000000000080000
INFOpartition-size:tz: 0x000000000007d000
INFOpartition-size:padA: 0x000000000040f000
INFOpartition-size:sbl1bak: 0x0000000000060000
INFOpartition-size:abootBackup: 0x0000000000100000
INFOpartition-size:rpmBackup: 0x0000000000040000
INFOpartition-size:utagsBackup: 0x0000000000080000
INFOpartition-size:tzBackup: 0x000000000007d000
INFOpartition-size:versions: 0x0000000000001000
INFOpartition-size:frp: 0x0000000000080000
INFOpartition-size:mdm1m9kefs1: 0x0000000000100000
INFOpartition-size:mdm1m9kefs2: 0x0000000000100000
INFOpartition-size:mdm1m9kefs3: 0x0000000000100000
INFOpartition-size:padB: 0x0000000000100000
INFOpartition-size:sp: 0x0000000001000000
INFOpartition-size:keystore: 0x0000000001000000
INFOpartition-size:logs: 0x0000000000200000
INFOpartition-size:persist: 0x0000000002000000
INFOpartition-size:mdm1hob: 0x0000000000040000
INFOpartition-size:mdm1dhob: 0x0000000000008000
INFOpartition-size:cid: 0x0000000000020000
INFOpartition-size:logo: 0x0000000000800000
INFOpartition-size:misc: 0x0000000000100000
INFOpartition-size:padD: 0x0000000000278000
INFOpartition-size:mdm1m9kefsc: 0x0000000000000400
INFOpartition-size:ssd: 0x0000000000002000
INFOpartition-size:recovery: 0x0000000001004000
INFOpartition-size:kpan: 0x00000000008e0000
INFOpartition-size:boot: 0x0000000001000000
INFOpartition-size:cache: 0x0000000010000000
INFOpartition-size:oem: 0x0000000004000000
INFOpartition-size:padC: 0x0000000000100000
INFOpartition-size:system: 0x0000000080000000
INFOpartition-size:userdata: 0x00000006a13e0000
INFOqe:
INFOro.carrier: unknown
INFOdm-verity-state: Not Supported
all: listed above
finished. total time: 0.129s
Press any key to continue . . .
The Following User Says Thank You to zishhaider For This Useful Post:
Old 11-15-2017, 16:59   #11 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 712
N6f27m/4299435 build
Old 12-09-2017, 00:54   #12 (permalink)
editodj's Avatar
Member: 2528726
Sonork: 100.1679759
Thanks Meter: 36
I can't reset frp on moto nexus 6 ... never activate adb .. please eft team help me !!!
Old 12-09-2017, 14:46   #13 (permalink)
editodj's Avatar
Member: 2528726
Sonork: 100.1679759
Thanks Meter: 36
Any solution? Please Help easy-team !!!
Old 01-06-2018, 16:46   #14 (permalink)
Member: 877421
Sonork: halim
Thanks Meter: 62
not work with last security N6f27m
Old 01-22-2018, 13:01   #15 (permalink)
Member: 2802619
how to fix g570 f
how to slove samsung g570f emergency call issue
Page generated in 0.24548 seconds with 8 queries
