08-22-2017, 10:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Syrian-Egypt Age: 26
Member: 2539108 Status: Offline Thanks Meter: 239 | How To root G900A 5.0 G900AUCU4BOF3 Easy-Team Moahmmed Hassn Al-Mahainiy First Step Flash G900A_UCU4DQA1_ATT4DQA1 4.4.2 SM-G900A | Easy-Firmware Download these Files : Root apk files G900A_ROOT_Ker_W0lfDroid.tar.md5 Root Via Root Kernel After Flash root Kerenl Install tr.apk Open towelroot app click Make it ra1n Reboot Device Now Device Is Rooted Via Kerenl Install Supersu apk open Supersu click install Normal After Finish Install SuperSu Before you do any thing, open SuperSU app on your phone, tap the Settings tab, scroll to Enable su during boot option and enable it Instal BusyBox.apk And install From App Now Install FlashFire Dowlond This Rom G900A_OF3_Stock_Rooted_ROM.zip https://www.androidfilehost.com/?fid=24052804347788226 And Copy to Your Device open FlashFire App And Click Agree Press + Now tap Flash Zip or OTA option and select the G900A_OF3_Stock_Rooted_ROM.zip Make sure that Auto-mount is unchecked under the Options menu and press the check-mark to continue When the installation is finished, your device will reboot automatically into the Download Mode Now Phone Stuck In Logo Inter In Download Mode And Flash G900A_OA1_Bootloader.tar.md5 https://www.androidfilehost.com/?fid=95916177934552761 Reboot Phone And Wait for Boot successfully Rooted Easy-Team Moahmmed Hassn Al-Mahainiy Last edited by easy-team; 09-20-2017 at 14:50. |
The Following 8 Users Say Thank You to HassanMahainiy For This Useful Post: |
08-22-2017, 15:50 | #4 (permalink) |
Member: 2539108 Status: Offline Thanks Meter: 239 | link G900A_UCU4DQA1_ATT4DQA1 4.4.2 SM-G900A | Easy-Firmware link G900A_ROOT_Ker_W0lfDroid.tar.md5 http://www.mega.co.nz/#!tRM2ELZT!vKd...87SZPr6PLhOpZ8 Last edited by easy-team; 08-22-2017 at 22:40. Reason: Add correct link for Root :) |
The Following 3 Users Say Thank You to HassanMahainiy For This Useful Post: |
10-28-2017, 09:07 | #8 (permalink) |
No Life Poster Join Date: Nov 2005 Location: 46000
Member: 197566 Status: Offline Thanks Meter: 89 | cant downgrade from 5.0 Message in Odin: <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> G900AUCU1ANCE_G900AATT1ANCE_G900AUCU1ANCE_HOME.tar .md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Added!! <ID:0/004> Odin engine v(ID:3.1005).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> aboot.mbn <ID:0/004> NAND Write Start!! <ID:0/004> FAIL! (Auth) <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
10-28-2017, 16:30 | #12 (permalink) |
Member: 197566 Status: Offline Thanks Meter: 89 | i found worked metod on xda This work on G900a android 5.0 and 6.0 Step 1: Use ODIN to flash the combination firmware. COMBINATION_ATT_FA44_G900AUCU4AOF1_ATT4AOF1_216696 8_REV00_user_mid_noship_MULTI_CERT.tar Step 2: After the OS is installed, go to the file manager and install Flashfire, SuperSU, and TowelRoot. Run towelroot. Simply hit "make it ra1n" and 3 seconds later you'll have the root binaries installed. Now open the SuperSU app and hit "new user", let it do its thing and then update the SU binaries (don't worry, its safe to reboot!) At this point you've got root! Now, let's get back to the present! Step 3: Open FlashFire, grant it root access, and flash the modified G900A_OF3_Stock_Rooted_ROM-from-noship with these settings: Mount /system read/write. Enter "flash", let it flash, reboot, and load. Combi APK ZIP |
The Following 3 Users Say Thank You to trt For This Useful Post: |
03-10-2018, 15:04 | #13 (permalink) | |
Major Poster Join Date: Jul 2015
Member: 2432275 Status: Offline Thanks Meter: 6 | Quote:
I have such a result, what did I do wrong? | |
