01-23-2024, 15:41 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 956861 Status: Offline Thanks Meter: 27 | ipad mini3 gsm/cdma icl bypass untethred ! ipad mini3 gsm/cdma icl bypass untethred with signal tested with chechrain jailbreak 0.10 and eft pro not working ! only tethred working . solution! |
01-23-2024, 19:34 | #3 (permalink) |
Member: 956861 Status: Offline Thanks Meter: 27 | only tethred work (eft pro) . untethred work (frpfile) Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated BuildVersion: 16H81 CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-4513.270.14 Device IMEI: 354422060057534 Device MEID: 35442206005753 Product Name: iPhone OS Product Type: iPad mini 3 (GSM+CDMA) IOS Version: 12.5.7 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F4KN975WG5W8 DeviceID: be75fbd7c15a6dc7d8eeae033c8492660ba2bf1a MEID Status: Supported Preparing paths.....OK Checking SSH......Checking SSH......P:14..OK Preparing device......OK IDevicePair......OK Downloading Hash........OK Activating...Checking Server...Checking Server...Checking Server...Checking Server...Checking Server......OK Wait please...Successfully! Operation {Bypass Carrier SIM Lock Gsm & Meid} ID: 28F012C5F68A6E5E Elapsed time 01:19 -- Version 4.6.3 Build 002 |
01-23-2024, 19:38 | #4 (permalink) | |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,230 | Quote:
01-23-2024, 20:03 | #5 (permalink) |
Member: 956861 Status: Offline Thanks Meter: 27 | I want to use the tablet without a SIM card, why does it work with the frpfile tool 2.8.6 application (the free server is cut for this application now) but it does not work on eft pro. I tested it several times on iOS 12. |
01-23-2024, 20:12 | #6 (permalink) | |
01-23-2024, 21:53 | #7 (permalink) |
Member: 956861 Status: Offline Thanks Meter: 27 | I did this test with these two applications there is one, the same result, there is no fix for this untethred problem in eft pro. in the frpfile bypass steps it appeared untethred fixed but for eft pro no. I successfully tested it for a few minutes on frpfile tool. where is the problem! Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated BuildVersion: 16H81 CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-4513.270.14 Device IMEI: 354422060057534 Device MEID: 35442206005753 Product Name: iPhone OS Product Type: iPad mini 3 (GSM+CDMA) IOS Version: 12.5.7 SIM Status: kCTSIMSupportSIMStatusReady Device Serial Number: F4KN975WG5W8 DeviceID: be75fbd7c15a6dc7d8eeae033c8492660ba2bf1a MEID Status: Supported Checking SSH......Checking SSH......P:14..OK Preparing device......OK IDevicePair...Mount......OK Find Activations......OK Preparing device......OK Delete Previous Activations...OK Snappy Starting!......OK Restart Lockdown!......OK iDevicePair......OK Checking Server......Checking Server......Checking Server......Checking Server......Checking Server.........OK Preparing device......OK Find Activations......OK Download Activations...OK Create Activations.....OK Preparing device......OK Upload Activation Files ......1....2....3....4....5....6....7....8.....OK Installing Basic Dylibs......OK Disable Reset Settings and Updates...OK Skip Setup......OK restart.......OK Successfullly!! Operation {Bypass iCloud GSM With Signal Up 14.5} ID: E323C5F49D60FC47 Elapsed time 02:10 -- Version 4.6.3 Build 002 |
01-24-2024, 10:55 | #8 (permalink) | |
Bypass iCloud MEID No Signal Up 14.8 | |
01-24-2024, 17:24 | #9 (permalink) |
Member: 956861 Status: Offline Thanks Meter: 27 | I tested before on the same option it gives different results, but now it works, I don't know where the problem comes from. Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated BuildVersion: 16H81 CPU Arch: arm64 Device Class: iPad Device Name: iPad de FJ7 Firmware Version: iBoot-4513.270.14 Device IMEI: 354422060057534 Device MEID: 35442206005753 Product Name: iPhone OS Product Type: iPad mini 3 (GSM+CDMA) IOS Version: 12.5.7 SIM Status: kCTSIMSupportSIMStatusReady Device Serial Number: F4KN975WG5W8 DeviceID: be75fbd7c15a6dc7d8eeae033c8492660ba2bf1a MEID Status: Supported Checking SSH......Checking SSH......P:14..OK IDevicePair......OK Mount......OK Find Activations......OK Preparing device.....OK Delete Previous Activations......OK Upload Dylibs.......OK IDevicePair......OK Checking Server...Checking Server...Checking Server...Checking Server...Checking Server......OK Find Activations......OK Download Activations...OK Create Activations.....OK Preparing device......OK Upload Activation Files ......1....2....3....4....5....6....7....8.....OK Installing Dylibs.......OK Disable Anti Reset and Disable Update......OK Preparing Untethered IOS 12-14X.......OK Preparing Untethered IOS 12-14X.......OK Successfully Activated! Operation {Bypass iCloud MEID No Signal Up 14.8} ID: A04881FA59376D43 Elapsed time 02:23 -- Version 4.6.4 Build 001 |
The Following User Says Thank You to ecrotek For This Useful Post: |
01-24-2024, 17:40 | #10 (permalink) | |
