Old 03-25-2024, 23:48   #1 (permalink)
Member: 2749393
Thanks Meter: 43
Ipad Pro 9.7 Icloud Bypass
Hello,
I need to bypass icloud Ipad pro 9.7 IOS 16.7.7
Can I bypass it without DCSD Cable?
Please help
Old 03-26-2024, 19:13   #2 (permalink)
Thanks Meter: 22,468
Originally Posted by D. Dragon View Post
Hello,
Please help
First, you need to change the serial number using tools that support this. After changing it, you can skip the serial number on the dongle. It should be the same as the one present in the dongle.
Old 03-26-2024, 19:46   #3 (permalink)
Member: 2749393
Thanks Meter: 43
Thank you sir,
But, Can I bypass it without DCSD Cable?
And if I Jailbreak it on MAC and then bypass is it support ios 16?
Please help
Old 03-26-2024, 21:13   #4 (permalink)
Thank you sir,
Please help
yes without DCSD Cable from one click sir
Old 03-26-2024, 21:34   #5 (permalink)
Member: 2749393
Thanks Meter: 43
I tried without change serial but failed and can't change serial with eft.
I also tried with jailbreak and operation done but still locked.
Any solution please
Old 03-27-2024, 03:55   #6 (permalink)
Member: 1311406
Thanks Meter: 3
Any solution please
DEVIVE have IMEI NO CHANGE SN 。if device no imei you must be change sn with eft pro support sn
Page generated in 0.14460 seconds with 8 queries
