01-31-2023, 09:53 | #1 (permalink) |
Banned Join Date: Oct 2016 Location: In Your Heart
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Iphon 7 Plus Always error Plz Check iDevices PWNDFU :..... Checking Drivers.....Ok Checking Drivers .....Ok Error! Tips to solve the problem: 1-Reconnect the Device Try Again 2-Download And install UsbDk_1.0.22_x64.msi: From: https://github.com/daynix/UsbDk/releases 3-Restart Your PC And Try Again Operation {Ipwnder Idevice A9/A10/A11} ID: 2100552BCBA101C0 Elapsed time 00:05 -- Version 4.4.0 |
01-31-2023, 10:09 | #3 (permalink) | |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Quote:
01-31-2023, 10:09 | #4 (permalink) |
Member: 2636401 Status: Offline Thanks Meter: 2,332 | When Phone Does not Boot In Ipwnder Mode I Am Not Be Able To Change SN Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated BuildVersion: 19H218 CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-7459.140.15 Device IMEI: 35380xxxxxxxxxx Product Name: iPhone OS Product Type: iPhone 7 Plus IOS Version: 15.7.2 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2MSVJXJHFYC DeviceID: 27740bc7ca800dde92ed7afc8eb6babb2af94c5f MEID Status: Not Supported Preparing Hello....Waiting for server.....OK Please change the serial number to (F17LTC4YFFDQ) and try again Operation {Hello Screen: Generate Activation files iCloud 15.x} ID: 0E4B1DC443BC9644 Elapsed time 00:02 -- Version 4.4.0 |
01-31-2023, 10:09 | #5 (permalink) |
01-31-2023, 10:15 | #6 (permalink) | |
https://www.youtube.com/watch?v=nBiz...nnel=EFTDongle | |
01-31-2023, 10:33 | #8 (permalink) | |
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Dear sir Quote:
iDevices PWNDFU :..... Checking Drivers.....Ok Checking Drivers .....Ok Error! Tips to solve the problem: 1-Reconnect the Device Try Again 2-Download And install UsbDk_1.0.22_x64.msi: From: https://github.com/daynix/UsbDk/releases 3-Restart Your PC And Try Again Operation {Ipwnder Idevice A9/A10/A11} ID: 99F978D3A98FEB33 Elapsed time 00:05 -- Version 4.4.0 | |
01-31-2023, 10:39 | #9 (permalink) | |
01-31-2023, 10:51 | #10 (permalink) | |
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Dear sir plz check Quote:
iDevices PWNDFU :..... Checking Drivers.....Ok Checking Drivers .....Ok Device CPU: A10 Waiting for server.....OK Please wait...Failed PWNDFU IS.....Failed Re-enter in DFU and Try Again! Operation {Ipwnder Idevice A9/A10/A11} ID: 92A80BE2D1F309C8 Elapsed time 00:19 -- Version 4.4.0 | |
01-31-2023, 17:07 | #12 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Suggest a problem on the Facebook support group and we will follow up with you there https://www.facebook.com/groups/easyfirmware |
The Following User Says Thank You to easy-team For This Useful Post: |
01-31-2023, 19:53 | #13 (permalink) |
Member: 2636401 Status: Offline Thanks Meter: 2,332 | DEAR SIR Plz Check Now Serial Driver Not Shown In Device Manager When I Update Driver Preparing.....OK Fix Drivers.........USB\VID_05AC&PID_1227&REV_0000.... .OK Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone 7 Plus (GSM) Product NAME: iPhone9,4 Device ECID: 0xa30ae2804ad26 Device CPID: 8010 Device SRTG: IBOOT-2696.0.0.1.33 Device MODE: DFU Device CPU: A10 Exploiting Device [1].... Sending File (iBoot.img4).....OK Sending File (iBoot.img4).....OK Sending File (diag.img4).....OK Successfully! Operation {Boot Purple Mode} ID: 92489D4243ACDEFA Elapsed time 01:47 -- Version 4.4.0 Select Port And Try Again |
01-31-2023, 20:12 | #14 (permalink) |
Member: 2636401 Status: Offline Thanks Meter: 2,332 | If I Check Driver Always Says Fix No Need Preparing.....OK Fix Drivers.........Is Fixed (No Need) Operation {Fix Drivers for Passcode IOS 11.x Up 15.x} ID: E67463293FDAE444 Elapsed time 00:09 -- Version 4.4.0 |
