Old 07-14-2022, 20:07   #1 (permalink)
Member: 327704
Thanks Meter: 84
iphone 6s+ PWNDFU IS.....Failed
i have try many time atill same error. iphone 6s+
iDevices PWNDFU :.....
Checking Drivers.....Ok
Checking UsbDk.....Ok
Device CPU: A09
Waiting for server.....OK
Please wait...Failed
Re-enter in DFU and Try Again!
Operation {Ipwnder Idevice A9/A10/A11} ID: B84A640E066B04C1
Elapsed time 01:05 -- Version 4.3.5
The Following User Says Thank You to ojongson For This Useful Post:
Old 07-15-2022, 09:08   #2 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
I have same problem. Whats wrong?
The Following User Says Thank You to stylius For This Useful Post:
Old 07-15-2022, 10:00   #3 (permalink)
Member: 2253202
Thanks Meter: 32
Device CPU: A09
Operation {Ipwnder Idevice A9/A10/A11} ID: 05F7C4D29AEC7A06
Elapsed time 01:29 -- Version 4.3.5
Old 07-15-2022, 10:01   #4 (permalink)
Member: 2253202
Thanks Meter: 32
Device CPU: A09
Old 07-15-2022, 10:03   #5 (permalink)
Member: 2253202
Thanks Meter: 32
Device CPU: A09
Preparing.....OK
Fix Drivers.........Is Fixed (No Need)
Checking iDevices (PWNDFU).....OK
Reading iDevice info.....OK
Device NAME: iPhone 6s
Product NAME: iPhone8,1
Device ECID: 0x637c9289ec8
Device CPID: 8000
Device SRTG: IBOOT-2234.0.0.3.3
Device MODE: DFU
Device CPU: A9
Exploiting Device [1]....
Sending File (shsh.shsh).....OK
Sending File (ibss.img4).....OK
Sending File (ibec.img4).....OK
Sending File (devicetree.img4).....OK
Sending File (ramdisk.img4).....OK
Exploiting Device [2]....
Sending File (kernel.img4).....OK
Failed! Check Drivers and Re-enter in PWNDFU and Try Again
Operation {Boot Passcode IOS 11.x Up 15.x} ID: 678D92182A44C13F
Elapsed time 01:23 -- Version 4.3.5
Old 07-15-2022, 10:23   #6 (permalink)
Member: 2120988
Thanks Meter: 25
need make usb flash drive for PWNDFU with 3utool like checkra1n. download from easy firmware pwndfu image
Old 07-15-2022, 14:12   #7 (permalink)
Member: 327704
Thanks Meter: 84
i PWNDFU with eft pro
Old 07-17-2022, 17:04   #8 (permalink)
Member: 327704
Thanks Meter: 84
how do you do please? I was able to pwndfu just once in 15 tried
Preparing.....OK
Device CPID: 8000
Device MODE: DFU
Device CPU: A9
Old 07-17-2022, 17:31   #9 (permalink)
Member: 1674096
Thanks Meter: 49
too much time wasted
how do you do please? I was able to pwndfu just once in 25 tried
please fix this problem
boot mth1 not working
Old 07-18-2022, 12:22   #10 (permalink)
Thanks Meter: 21,230
Sir, not from the first attempt it works, there are some errors in the driver
Old 07-18-2022, 16:27   #11 (permalink)
Member: 327704
Thanks Meter: 84
very difficult to use like that. I have tried more than 45 times without success iPhone 6s+. and many times while waiting the software will just close by itself. and I will have to open it again and try. and by the USB key, I have no luck. it says device pwndfu but the software says no pwndfu
please if you can fix it dear team
Old 07-19-2022, 03:46   #12 (permalink)
Member: 2183315
Thanks Meter: 21
https://mega.nz/file/Z64liCbJ#hZv_74...oBARQ3b5QHaqXY
The Following 2 Users Say Thank You to jason_ach For This Useful Post:
Old 07-19-2022, 04:09   #13 (permalink)
Member: 2183315
Thanks Meter: 21
Thumbs down
same case with iphone 6s+
Preparing.....OK
Device NAME: iPhone 6s Plus
Product NAME: iPhone8,2
Device ECID: 0xe595020d3e0a6
Device CPID: 8003
Device SRTG: IBOOT-2234.0.0.2.22
Device MODE: DFU
Device CPU: A9
Operation {Boot Passcode IOS 11.x Up 15.x} ID: FCB82BEFFD62D4D2
Elapsed time 00:58 -- Version 4.3.5
ps:dont tell me drivers problem
Old 07-19-2022, 10:22   #14 (permalink)
Preparing.....OK
Device CPID: 8003
Device MODE: DFU
Device CPU: A9
It comes after ibss or ibec, press the power button for three seconds, then it separates and completes the steps
Old 07-19-2022, 19:47   #15 (permalink)
Member: 2183315
Thanks Meter: 21
Already do this triks but same result,check your Software please,the problem only with iphone 6s/6s+ with cpu A09.
Other CPU A10/A11 work fine Tested 100°/°
The Following User Says Thank You to jason_ach For This Useful Post:
Page generated in 0.25377 seconds with 8 queries
