01-25-2024, 19:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | No damaged repair chip Huawei 8i Download port: Qualcomm HS-USB QDLoader 9008 (COM2) Port: Qualcomm HS-USB QDLoader 9008 (COM2) Manufacturer: Qualcomm Incorporated Waiting for server........ OK Connect to comport... OK Read chip info... OK Hardware ID: 0x14D0E1 OEM Private key: 0xB25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D1 2606199F5099FF23 Vendor: HUAWEI Load loader... OK Send Loader... OK Ping Device... OK Load Config... OK Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Read Build Prop Info... FAIL [FS ERR] FAILED TO MOUNT /SYSTEM/ Read Internal Storage Info... OK USERDATA: 111.07 GB USERDATA: ENCRYPTED Read Partition Table... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... Server ... OK Get Partition ... OK Read Build Prop Info... FAIL [FS ERR] FAILED TO MOUNT /SYSTEM/ Read Internal Storage Info... OK USERDATA: 111.07 GB USERDATA: ENCRYPTED Calculating Chip Data... OK Repair Chip Data... OK Reset factory default... OK ● NOTE : Reset Phone Manually From Recovery Once Again If The ID Is Not Removed:... Reboot... OK Elapsed Time: 28 secs, 469 msecs Read Partition Table... FAIL [PORT ERR] DEVICE DISCONNECTED |
The Following User Says Thank You to m&s For This Useful Post: |
