Oppo A93 Formatting Failed ??? 1 Attachment(s) Oppo A93 Formatting Failed Tried on 2 different Pcs and it gives the same error Any Suggestions ? |
Please Help! Oppo A93 not connecting to system even after installing drivers, stuck on WAITING FOR MTK PORT. |
Format done but the phone still has FRP Locked can you help me too? Waiting for server.....OK Loading files.....OK Setting up.....OK Waiting for MTK port.....Detected {COM29} Switching to Meta Mode.....OK Waiting for Meta port.....Detected {COM30} Connecting to Meta port.....OK Reading info.....OK Device SDK: 29 Device data encryption: encrypted Device Hardware: mt6779 Device CPU: arm64-v8a Device Factory: OPPO Device Factory: OPPO Device Factory: OPPO Device Model: CPH2121 Android version: 10 Device Firmware: CPH2121_11_A.19 Executing Erase command.....OK - Note: if device not entered to recovery and process format automatically then - Boot to recovery manually and perform factory reset Operation {Factory Reset META Recovery} ID: 32A1627366DE127A Elapsed time 00:39 -- Version 3.9.3 |
Thank you sir, is it possible to remove or bypass FRP? If yes can you help me? |
Not supported by us sorry ! |
I have remove it by dialing this code *#812# and following this stape https://www.bypassfrpfiles.com/2021/...unlock-google/ |
*#813# english easy theard |
