10-23-2020, 15:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: México
Member: 1070713 Status: Offline Thanks Meter: 14 | What about bypass errors team? Please answer Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-4513.270.14 Product Name: iPhone OS Product Type: iPad Air (WiFi) IOS Version: 12.4.8 Device Serial Number: DMQLMCPQFK10 MEID Status: Not Supported Preparing.....OK Bypassing.....Failed: UnKnown Error Operation {Bypass iCloud at Hello Screen} ID: 34BDAC2149496FFB Elapsed time 00:08 -- Version 3.5.0 Iphone X gsm: Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPhone Device Name: iPhone Firmware Version: iBoot-4513.270.14 Device IMEI: 353041098817130 Product Name: iPhone OS Product Type: iPhone X GSM IOS Version: 12.4.1 SIM Status: kCTSIMSupportSIMStatusNotInserted Device Serial Number: F2LW44DCJCL9 MEID Status: Not Supported Preparing.....OK Bypassing.....Failed: UnKnown Error Operation {Bypass iCloud at Hello Screen} ID: EF65F990A223C5FC Elapsed time 00:10 -- Version 3.5.0 |
10-23-2020, 17:25 | #2 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,230 | Already lots of users have success reports sir . What ever the problem is it is form your side , as long as it is working at last , the dongle is programmed with one code for all users . make sure device is not asking for authentication or no other program is using the same port !! |
10-23-2020, 17:36 | #3 (permalink) | |
Member: 1070713 Status: Offline Thanks Meter: 14 | Quote:
10-23-2020, 18:03 | #5 (permalink) |
Member: 1070713 Status: Offline Thanks Meter: 14 | A friend of mine helped me with his eft pro dongle and everything ok at first try.. I have bought digital activation is there any difference?? Please help i need to try in another pc could you help me to transfer to other pc my license please |
11-09-2020, 06:50 | #7 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
I was having same issue so i just used a different cable and everything worked fine... | |
08-24-2021, 13:06 | #8 (permalink) |
Junior Member Join Date: Apr 2013 Location: Jhapa, Nepal
Member: 1925534 Status: Offline Thanks Meter: 4 | Preparing paths.....OK Setting up.....OK Checking iDevices.....OK Reading iDevice info.....OK Activation Status: Unactivated CPU Arch: arm64 Device Class: iPad Device Name: iPad Firmware Version: iBoot-5540.0.129 Product Name: iPhone OS Product Type: iPad Pro (12.9 inch IOS Version: 13.1.1 Device Serial Number: DLXQK6CWGMLG MEID Status: Not Supported Preparing.....OK Bypassing.....Failed Operation {Bypass iCloud at Hello Screen} ID: 10479A895C999F56 Elapsed time 01:10 -- Version 4.0.3 Need Best solution urgent Thank You |
