10-08-2022, 22:09 | #2 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2242140 Status: Offline Sonork: 100.1658107 Thanks Meter: 6 | 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Custom firhose loader - Process : Flash ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM77 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E06E000 BLOCK_ID_S : BD46C30C BLOCK_ID_H : 6OROR8318N1236QO9O56531518552889 BLOCK_ID_H : QR4R0PN69426P2P9S9803RP4Q24PQN91 Executing boot : DONE Version : 6 Code Size : 864 Signature Size : 256 Header Type : NEW FhVendor : XIAOMI HW ID : 0000000000720000 SW ID : 00000003 OEM ID : 0072 Vendor : XIAOMI Model ID : 0000 APP ID : 00000000 Pk Hash : 1BEBE3863A6781DB4B01086063007334DE9E5CA14971C7C4F4 358EC9D79CDA46 Configuring : Failed Device requires authorization Connecting to UAT server Checking UAT server online status UAT server is online Reading authorization blob... OK Blob : [ WD34aJSsBoEpWE57EToXTxAAEAAQABAAEAAQABAAEAA= ] Sending request to Server Waiting for signature @256bytes authentication Signature authentication rejected HINT : Turn off phone, remove battery, keep power button pressed for 10-15 seconds without battery. Short Test Points, and connect USB cable. Once you see EDL port in device manager, connect battery and try repeating process. |
