Help me qualcomm unlock qualcomm unlock ZTE 955L or please create a video for qualcomm already 3-4 phones are |
-- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : Z955L -- MANUFUCTURER : zte -- ANDROID VERSION : 5.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : 2015年 07жњ€ 08ж—Ґ ж˜џжњџдё‰ 16:02:11 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : kingo 14 -- Operation : SP LOCK [QUALCOMM] -- This device is not supported. -- Operation Aborted !! -- Elapsed Time : 0 minutes - 16 seconds |
-- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : Micromax Q415 -- MANUFUCTURER : Micromax -- ANDROID VERSION : 5.1.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : Fri Apr 8 10:05:10 CST 2016 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : kingo 14 -- Operation : SP LOCK [QUALCOMM] -- This device is not supported. -- Operation Aborted !! -- Elapsed Time : 0 minutes - 13 seconds |
sorry but which models support |
https://s1.postimg.org/6v2g88p027/screenshot_360.png |
help please get into the injector menu on ZTE 955L * 983 * 87274 # did not help |
If the code did not work then you should Root Device Enable Diagnostic Port and try with Direct Unlock in Qualcomm Tab. Sent from my SM-G920F using Tapatalk |
but I did the result here -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : Z955L -- MANUFUCTURER : zte -- ANDROID VERSION : 5.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : 2015年 07жњ€ 08ж—Ґ ж˜џжњџдё‰ 16:02:11 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : kingo 14 -- Operation : SP LOCK [QUALCOMM] -- This device is not supported. -- Operation Aborted !! -- Elapsed Time : 0 minutes - 16 seconds |
https://s1.postimg.org/33eqlmuabz/screenshot_362.png |
I have a port does not show ADB and all help me how to create a port or give an injector menu code |
I do not have a Skype |
