10-14-2017, 09:08 | #2 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2054990 Status: Offline Sonork: 12 Thanks Meter: 0 | -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : Z955L -- MANUFUCTURER : zte -- ANDROID VERSION : 5.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : 2015年 07жњ€ 08ж—Ґ ж˜џжњџдё‰ 16:02:11 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : kingo 14 -- Operation : SP LOCK [QUALCOMM] -- This device is not supported. -- Operation Aborted !! -- Elapsed Time : 0 minutes - 16 seconds |
10-14-2017, 09:19 | #3 (permalink) |
Member: 2054990 Status: Offline Sonork: 12 Thanks Meter: 0 | -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : Micromax Q415 -- MANUFUCTURER : Micromax -- ANDROID VERSION : 5.1.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : Fri Apr 8 10:05:10 CST 2016 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : kingo 14 -- Operation : SP LOCK [QUALCOMM] -- This device is not supported. -- Operation Aborted !! -- Elapsed Time : 0 minutes - 13 seconds |
10-16-2017, 07:21 | #8 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | If the code did not work then you should Root Device Enable Diagnostic Port and try with Direct Unlock in Qualcomm Tab. Sent from my SM-G920F using Tapatalk |
10-16-2017, 07:25 | #9 (permalink) |
Member: 2054990 Status: Offline Sonork: 12 Thanks Meter: 0 | but I did the result here -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : Z955L -- MANUFUCTURER : zte -- ANDROID VERSION : 5.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : 2015年 07жњ€ 08ж—Ґ ж˜џжњџдё‰ 16:02:11 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : kingo 14 -- Operation : SP LOCK [QUALCOMM] -- This device is not supported. -- Operation Aborted !! -- Elapsed Time : 0 minutes - 16 seconds |
10-16-2017, 08:27 | #10 (permalink) | |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Quote:
