Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 12-22-2022, 10:59   #1 (permalink)
Member: 65145
Sonork: skype: hristo_el1
Thanks Meter: 3
Huawei nova 9SE after remove Huawei ID security chip damaged [SOLVED]
Hi after remove Huawei ID on Nova 9se JLN LX1 security chip is damage and cannot activate device.
How can fix this problem
Thanks
Old 01-10-2023, 07:25   #2 (permalink)
Nishan_Raja's Avatar
Member: 2554807
Thanks Meter: 612
already Supported on UAT
Thanks
UAT PRO Version : 150.01
Release Notes:
[ADDED] - ONE CLICK HUAWEI HONOR FIX DAMAGED CHIP
No need of erase oeminfo, No need to write persist, No need multi reboots and bla bla .. just one click
Old 01-11-2023, 01:59   #3 (permalink)
Member: 710668
Thanks Meter: 121
Release Notes:
is this method tested? i have 1 here in my hand.....
WHAT ABOUT YOU " hrito5 " did it solve your problem?
Old 01-12-2023, 19:29   #4 (permalink)
Member: 85100
Thanks Meter: 16
Not work
1. Power off device
2. Press and hold volume up + volume down insert usb cable
3. In some case requires special edl cable or test points
4. Install Qualcomm drivers if needed
- Connection : EDL
- Method : By Model
- Brand : Huawei
- Model : JLN-LX3 (Nova 9 SE)
- Process : Remove Huawei ID
Waiting for QDLoader port ...
Port found
Device on Port : [ COM53 : Qualcomm HS-USB QDLoader 9008 ]
Analyzing Sahara please wait ...
HW_ID : 0001E08B100
BLOCK_ID_S : 18452D48
BLOCK_ID_H : O70QRPQ30Q762S0Q4O08QP8P97RS2391
BLOCK_ID_H : QPRS04QQ8R5NS9Q67151644S0544SS78
Executing boot : DONE
Version : 6
Code Size : 816
Signature Size : 512
Header Type : NEW
FhVendor : QUALCOMM
HW ID : 000000000015006D
SW ID : 00000003
OEM ID : 0015
Vendor : HUAWEI
Model ID : 006D
APP ID : 00000000
Pk Hash : B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23
Configuring : DONE
Reading Parts : DONE
Capacity : 14,75 GB
Userdata : 13,67 GB
Reading GPT : DONE
Partition Count : 76
MEM_TYPE : UFS
Max_Payload_Size_InBytes : 1048576
Max_Payload_Size_Supp. : 1048576
Max_XML_Size : 4096
Version : 1
Date_Time : Mar 11 2022 - 18:36:43
Userdata : Encrypted
Processing Huawei id data ...
Process done
Prepairing id data please wait....
Data prepairation done
Patching Huawei id ...
Huawei ID Patch done
Setting up device please wait...
Device setup done
1. If Huawei ID is not removed
2. Please press and hold volume up + power to goto recovery
3. Wipe cache / userdata or wipe all data from recovery and reboot.
4. First startup may take few minutes to power on
UAT PRO : 150.01 | 12 - január - 2023 [ 19:26:59 ]
Elapsed Time : 10 seconds
After remove Huawei id chip is damaged
Repair not work
1. Power off device
- Connection : EDL
- Method : By Model
- Brand : Huawei
- Process : Honor Fix Chip Damage
Port found
HW_ID : 0001E08B100
Version : 6
Code Size : 816
Header Type : NEW
FhVendor : QUALCOMM
SW ID : 00000003
OEM ID : 0015
Vendor : HUAWEI
Model ID : 006D
APP ID : 00000000
Configuring : DONE
Capacity : 14,75 GB
Userdata : 13,67 GB
Reading GPT : DONE
MEM_TYPE : UFS
Max_XML_Size : 4096
Version : 1
Processing data from device ...
Process done
Prepairing data please wait....
Checking damaged data in device ...
Error : data not found
UAT PRO : 150.01 | 12 - január - 2023 [ 19:25:34 ]
Elapsed Time : 7 seconds
Old 01-12-2023, 21:08   #5 (permalink)
Member: 85100
Thanks Meter: 16
Originally Posted by rastob View Post
Not work
1. Power off device
- Connection : EDL
- Method : By Model
- Brand : Huawei
Port found
HW_ID : 0001E08B100
Version : 6
Code Size : 816
Header Type : NEW
FhVendor : QUALCOMM
SW ID : 00000003
OEM ID : 0015
Vendor : HUAWEI
Model ID : 006D
APP ID : 00000000
Configuring : DONE
Capacity : 14,75 GB
Userdata : 13,67 GB
Reading GPT : DONE
MEM_TYPE : UFS
Max_XML_Size : 4096
Version : 1
Process done
Device setup done
Repair not work
1. Power off device
- Connection : EDL
- Method : By Model
- Brand : Huawei
Port found
HW_ID : 0001E08B100
Version : 6
Code Size : 816
Header Type : NEW
FhVendor : QUALCOMM
SW ID : 00000003
OEM ID : 0015
Vendor : HUAWEI
Model ID : 006D
APP ID : 00000000
Configuring : DONE
Capacity : 14,75 GB
Userdata : 13,67 GB
Reading GPT : DONE
MEM_TYPE : UFS
Max_XML_Size : 4096
Version : 1
Process done
Problem solved in one click.New update working.Thanks Mehmood Riaz
Old 01-17-2023, 21:24   #6 (permalink)
Member: 2487193
Hello. I have same problem. PLS show me, how you solv this error?
Old 01-18-2023, 08:16   #7 (permalink)
Member: 499093
Thanks Meter: 26
also having same issue honor fix not working
Old 01-18-2023, 09:25   #8 (permalink)
Member: 499093
Thanks Meter: 26
solved with upcoming update
solved with upcoming update great support
Page generated in 0.21825 seconds with 8 queries
