06-11-2021, 15:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Huawei Y5 2018 (DRA-LX1) Can`t Read Info So I want to write Scatter Firmware on it to revive but tool is still not read it. I tried already With/Without model and different DA but in the end result is same. Even manual DA have same error like below. 1:- Sending DA Download-Agent : DENIED (STATUS_DA_SELECTION_ERR) 2:- Sending DA Download-Agent : DENIED (STATUS_PRELOADER_INVALID) Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Huawei Model : Huawei Y5 2019 AMN-LX2 Process : Read Info. ==================================== Searching for device... Device found MediaTek USB Port (COM25) Mode : Brom Port Port : COM25 Handshaking : DONE Hw code: 0x0699 - [MT6739] Hw sub code: 0x8A00 Hw version: 0xCB00 Sw version: 0x0002 Sl auth: Yes Da auth: No Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2018/10/18.17:38_452898 Drivers : MediaTek Inc. Driver Date : 06/10/2014 Driver Version : 2.0.1136.0 Handshaking : DONE Loading MTK Auth File : DONE Loading Preloader : DONE Connecting to Brom : DONE Chip name : [MT6739] Sending DA Download-Agent : DENIED (STATUS_DA_SELECTION_ERR) ========================================== 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Huawei Model : Huawei Y5 2018 DRA-L02 Process : Read Info. ==================================== Searching for device... Device found MediaTek USB Port (COM25) Mode : Brom Port Port : COM25 Handshaking : DONE Hw code: 0x0699 - [MT6739] Hw sub code: 0x8A00 Hw version: 0xCB00 Sw version: 0x0002 Sl auth: Yes Da auth: No Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2018/02/27.12:46_402229+403250 Drivers : MediaTek Inc. Driver Date : 06/10/2014 Driver Version : 2.0.1136.0 Handshaking : DONE Loading MTK Auth File : DONE Connecting to Brom : DONE Chip name : [MT6739] Sending DA Download-Agent : DENIED (STATUS_PRELOADER_INVALID) ================================================================== 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Huawei Model : Huawei Y5 Prime 2018 DRA-LX2 Process : Read Info. ==================================== Searching for device... Device found MediaTek USB Port (COM25) Mode : Brom Port Port : COM25 Handshaking : DONE Hw code: 0x0699 - [MT6739] Hw sub code: 0x8A00 Hw version: 0xCB00 Sw version: 0x0002 Sl auth: Yes Da auth: No Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2018/02/27.12:46_402229+403250 Drivers : MediaTek Inc. Driver Date : 06/10/2014 Driver Version : 2.0.1136.0 Handshaking : DONE Loading MTK Auth File : DONE Connecting to Brom : DONE Chip name : [MT6739] Sending DA Download-Agent : DENIED (STATUS_PRELOADER_INVALID) ======================================= But other tool done work properly without anything hesitation or manual DA and mobile has turn on. In future if same model come in my hand for Reset/FRP/Flash then how to resolve this issue on that time ??? |
06-11-2021, 15:14 | #2 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,532 | We will check and fix it .. but as per screen shots you have used Authorization bypass method , but you did not try by Preloader port by selecting manual DA if internal DA failed. and if you are using authorization bypass method then you need to select preloader manually. If you want to see its working for future please contact me on Telegram @MehmoodRiaz |
06-11-2021, 15:49 | #3 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
06-12-2021, 09:47 | #4 (permalink) | |
Now its working with the help of manual Da+AT+PL. These files work on any DRA-XXX model. Files link :- ****************************/file/qf7qg...saqib.zip/file Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : Custom DA Process : Read Info. ==================================== Searching for device... Device found MediaTek USB Port (COM25) Mode : Brom Port Port : COM25 Handshaking : DONE Hw code: 0x0699 - [MT6739] Hw sub code: 0x8A00 Hw version: 0xCB00 Sw version: 0x0002 Sl auth: Yes Da auth: No Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2018/02/27.12:46_402229+403250 Drivers : MediaTek Inc. Driver Date : 06/10/2014 Driver Version : 2.0.1136.0 Handshaking : DONE Loading MTK Auth File : DONE Loading Preloader : DONE Connecting to Brom : DONE Chip name : [MT6739] Sending DA Download-Agent : ACCEPTED Identifying Hardware ID ... ==================================== ChipID : MT6739 Software Ver : 0002 Hardware Ver : CB00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0x40000000 SRAM : 0x00040000 Storage : 0x03A4A00000 ==================================== RAM Size : 1.000 GB SRAM Size : 256.000 KB Storage Size : 14.572 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 47 Reading system Information... Model : DRA-LX5 Hardware : DRA-LX5 Android Ver. : 8.1.0 Android OS : Oreo CPU : armeabi-v7a Display id : DRA-LX5 1.0.0.156(C185) Build Date : Thu Feb 25 12:19:01 CST 2021 Build id : HUAWEIDRA-LX5 Security Patch : 2020-10-01 Brand : HUAWEI Manufacturer : HUAWEI Product : DRA-LX5 Local lang. : en-US DONE BY UAT MTK MODULE : 3.01 Elapsed Time : 00:00:03 Now! I have another issue here. I cant write OEMINFO file | |
