07-25-2020, 19:32 | #8 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,532 | It is either pinouts are not properly made or it is isp hardware failure. |
The Following 2 Users Say Thank You to Mehmood Riaz 1 For This Useful Post: |
07-25-2020, 22:05 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Phone is CPH1893 ... I`ve made the pinout after Oppo k1 schematics But after some research I`ve found out that CPH1893 is also R17 Neo Is this the same product for another region ? Board looks the same.... does it have different testpoints ? |
02-24-2021, 23:01 | #10 (permalink) |
Junior Member Join Date: May 2014
Member: 2182702 Status: Offline Thanks Meter: 0 | Oppo RX17 Neo I also tried and tried to connect via ISP in the same way to the Oppo RX 17 Neo via Easy EMMC. Spent two days picking different pull-up resistors along the lines. It didn't work. Could the wiring diagram be really wrong? |
04-02-2021, 13:52 | #11 (permalink) |
Member: 2182702 Status: Offline Thanks Meter: 0 | He took off the memory chip and put it on the block. It clings without problems. I called and checked the ISP pinout - it is correct. But for some reason I could not get hold of the wires. |
