10-21-2021, 11:25 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Russia
Member: 1412935 Status: Offline Thanks Meter: 81 | Mi 8 lite Read Info error [SOLVED] Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Xiaomi - Model : Mi 8 Lite (Platina) - Process : Read Info. ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM18 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0C8000 | Snapdragon 660 BLOCK_ID_S : 21F2B665 BLOCK_ID_H : N2O3O37090N43RPN78Q1R4650SO91901 BLOCK_ID_H : 3Q6O0373719458996OQRS5PQ02R8P825 Executing boot : Done Configuring : Failed Device requires authorization Connecting to UAT server Checking UAT server online status UAT server is online Reading authorization blob... OK Blob : [ ewPtNbDBovbaGpbk8lOy+IshexD8CS858vJJPOxCWBppAb7YxwlnyNS ] Sending request to Server Waiting for signature @256bytes authentication Signature authentication rejected HINT : Turn off phone, remove battery, keep power button pressed for 10-15 seconds without battery. Short Test Points, and connect USB cable. Once you see EDL port in device manager, connect battery and try repeating process. |
10-21-2021, 13:02 | #3 (permalink) |
Member: 1412935 Status: Offline Thanks Meter: 81 | It's done. Thanks. Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Read Info. ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM18 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0C8000 | Snapdragon 660 BLOCK_ID_S : 21F2B665 BLOCK_ID_H : N2O3O37090N43RPN78Q1R4650SO91901 BLOCK_ID_H : 3Q6O0373719458996OQRS5PQ02R8P825 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 116,48 GB Userdata : 108,23 GB Partition Count : 79 Drivers : Qualcomm Technologies, Inc. Driver Version : 03/25/2016,2.1.2.2 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8996] Date_Time : Aug 2 2018 - 22:27:53 Userdata : Encrypted Reading Device Information... Android Ver. : 10 CPU : arm64-v8a Android OS : Quince Tart MIUI Version : V12 MIUI Code : 10 Build Date : Fri Sep 4 11:41:33 WIB 2020 Build id : QKQ1.190910.002 Security Patch : 2020-08-01 Manufacturer : Xiaomi Device Mod : platina_ru_global Local lang. : en-GB Read info. done UAT PRO : 133.02 | 21 - Октябрь - 2021 Elapsed Time 6 seconds |
The Following User Says Thank You to chuikoff For This Useful Post: |
