05-13-2022, 20:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | Need help huawei g630 bootloader and flash [SOLVED] No way to get bootloader unlocked so no way to use fastboot flash because all commands will fail. i am not an expert in huawei flashing. i tried edl mode and got the error in the following log. can anyone help with this case? Best Regards 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Flash ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM46 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E041800 | Snapdragon 200 BLOCK_ID_S : 0044A43E BLOCK_ID_H : PP8608N35748484O45Q57Q8OS3O78R57 BLOCK_ID_H : 47R907SRS117P29443976NQNQ97N835S Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 2.76 GB Userdata : 1024 MB Partition Count : 25 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 49152 Max_Payload_Size_Supp. : 49152 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8x26] Userdata : UnEncrypted Reading Device Information... Model : G630-U20 Hardware : G630-U20 Android Ver. : 4.3 CPU : armeabi-v7a Android OS : Jelly Bean Platform : msm8610 Build Date : Mon Mar 31 02:49:46 CST 2014 Build id : HuaweiG630-U20C00B112 Brand : Huawei Manufacturer : HUAWEI Product : G630-U20 Carrier : unknown GsmVersion : 4.3_r1 Writing : [md5rsa] ... [md5rsa.img] ... Fail |
05-13-2022, 23:31 | #2 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 587 | Solved skipping some files ´ now phone working perfectly 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : Auto detect - Process : Flash ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM46 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E041800 | Snapdragon 200 BLOCK_ID_S : 0044A43E BLOCK_ID_H : PP8608N35748484O45Q57Q8OS3O78R57 BLOCK_ID_H : 47R907SRS117P29443976NQNQ97N835S Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 2.76 GB Userdata : 1024 MB Partition Count : 25 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 49152 Max_Payload_Size_Supp. : 49152 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8x26] Userdata : Encrypted Reading Device Information... Model : G630-U20 Hardware : G630-U20 Android Ver. : 4.3 CPU : armeabi-v7a Android OS : Jelly Bean Platform : msm8610 Build Date : Fri May 16 06:12:36 CST 2014 Build id : HuaweiG630-U20 Brand : Huawei Manufacturer : HUAWEI Product : G630-U20 Carrier : unknown GsmVersion : 4.3_r4 Writing : [gpt] ... [gpt.img] ... Done Writing : [rpm] ... [rpm.img] ... Done Writing : [tz] ... [tz.img] ... Done Writing : [sbl1] ... [sbl1.img] ... Done Writing : [modem] ... [modem.img] ... Done Writing : [sdi] ... [sdi.img] ... Done Writing : [modemst1] ... [modemst1.img] ... Done Writing : [modemst2] ... [modemst2.img] ... Done Writing : [fsg] ... [fsg.img] ... Done Writing : [aboot] ... [aboot.img] ... Done Writing : [recovery] ... [recovery.img] ... Done Writing : [system] ... [system.img] ... bg565Done Writing : [userdata] ... [userdata.img] ... Done Writing : [cache] ... [cache.img] ... Done Writing : [cust] ... [cust.img] ... Done Writing : [persist] ... [persist.img] ... Done Writing : [boot] ... [boot.img] ... Done Formatting userdata Formatting userdata done Writing patch0 : Done Write Firmware successfully done. All done... UAT PRO : 139.01 | 14 - May - 2022 [ 12:26:57 AM ] Elapsed Time : 5 minutes 36 seconds |
The Following User Says Thank You to Punto-Móvil For This Useful Post: |
