04-17-2018, 16:28 | #1412 (permalink) |
Insane Poster Join Date: Feb 2018 Location: Brazil
Member: 2807526 Status: Offline Thanks Meter: 67 | LG D690N FACTORY RESET DONE!!! Checking Current Version Current Version OK Checking User Login User Login OK. Searching Device on Modem Port..... Device Found Reading Info.... Manufacturer : Model : Soft. Version : LGD690nAT-00-V20a-SCA-XXX-SEP-10-2015+0 Device Chip : QC Android Version : 5.0.2 IMEI : 35560********* Factory Resetting, Please Wait.... Factory Reset Done |
The Following User Says Thank You to DanielSantoz For This Useful Post: |
04-17-2018, 17:16 | #1413 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | FRP BYPASS MOTO MAXX Checking Current Version Current Version OK Checking User Login User Login OK. Searching for Device - Found Reading Info. Modal : XT1225 IMEI : 353********** Version : 0.5 Bootloader : moto-apq8084-70.96 Ram : 3072MB Elpida S8 SDRAM DIE=6Gb UID : 9BE68E0111000000000000000000 Relased Date : 2015-09-22 Baseband : MDM9625_104438.245.02.85R QUARK_SINGLE CPU : APQ8084 ES1.1 Serial No. : 0017721315 Cid : 0x000C Setting Factory Mode... Done Connecting to device... OK Android Version : Bootloader : moto-apq8084-70.96 Baseband : MDM9625_104438.245.02.85R QUARK_SINGLE Connecting to device... OK Android Version : Bootloader : moto-apq8084-70.96 Baseband : MDM9625_104438.245.02.85R QUARK_SINGLE Modal : XT1225 Android : 6.0.1 Manufucture : motorola CPU : armeabi-v7a Hardware : qcom Bootloader : 0x7096 Baseband : mdm Platform : apq8084 Enabling Adb..... Done All done Successfully. -- Searching Device -- Found -- MODAL : XT1225 -- MANUFUCTURER : motorola -- ANDROID VERSION : 6.0.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : Tue Jan 17 04:30:18 CST 2017 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Not Rooted -- Operation : FRP RESET -- Resetting Frp Please wait... -- Frp Reset done -- Elapsed Time : 0 minutes - 3 seconds |
04-17-2018, 19:25 | #1415 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | FRP BYPASS BLU ADVANCED 4.0 L2 Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6580 Software Version : 0000 Hardware Version : 00CA Ram info. : 0xFD65800000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 10 seconds |
04-17-2018, 20:53 | #1416 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2522648 Status: Offline Thanks Meter: 2 | XT1635-01 frp remove Checking Current Version Current Version OK Checking User Login User Login OK. Searching for Device - Found Reading Info. Modal : XT1635-01 IMEI : 351873081788213 Version : 0.5 Bootloader : moto-msm8953-C1.13 Stroage Type : emmc Ram : 3GB SAMSUNG LP3 DIE=6Gb M5=01 M6=05 M7=00 M8=7B UID : F9F3671100000000000000000000 Relased Date : 06-08-2017 CPU : MSM8953 Serial No. : ZY2246JXFD Cid : 0x0002 Setting Factory Mode... Done Connecting to device... OK Android Version : Bootloader : moto-msm8953-C1.13 Baseband : Connecting to device... OK Android Version : Bootloader : moto-msm8953-C1.13 Baseband : Modal : XT1635-01 Android : 7.1.1 Manufucture : motorola CPU : armeabi-v7a Hardware : qcom Bootloader : 0xC113 Baseband : msm Platform : msm8953 Resetting Frp..... Done All done Successfully. |
The Following User Says Thank You to dj_anthon For This Useful Post: |
04-18-2018, 09:44 | #1417 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Turkey Age: 39
Member: 311347 Status: Offline Sonork: 100.1672192 Thanks Meter: 486 | Vodafone Smart Style 7 VFD600 FRP Success Vodafone Smart Style 7 VFD600 FRP Success |
The Following User Says Thank You to gsmkolik For This Useful Post: |
04-19-2018, 13:17 | #1418 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | J110b imei repair done!!! Repair network but not done (i use another tool for network repair) :/ |
04-19-2018, 13:20 | #1419 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | ALCATEL PIXI4 4034E FIRMWARE FLASH DONE!!! Flash Process started... Tips: 1. Remove Battery, Insert usb cable, Insert battery 2. power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Requires to hold bootkey) Waiting for Phone Usb.... Phone found on : COM6 COM port is open. Trying to sync with the target... Flashing Device Please Wait .... Flashing Successfuly Done. Rebooting Device into Normal Mode ... Please Wait few Seconds to get Device in Normal Mode ... Elapsed Time : 2 minutes - 14 seconds |
The Following 3 Users Say Thank You to DanielSantoz For This Useful Post: |
04-19-2018, 13:23 | #1420 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | FRP PIXI4 4034E DONE!!! Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6580 Software Version : 0000 Hardware Version : 00CA Ram info. : 0xFD65800000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 10 seconds MTK DETECTION DRIVES ARE FIXED!!! |
04-19-2018, 21:22 | #1421 (permalink) |
Member: 2807526 Status: Offline Thanks Meter: 67 | GT-I9063T REPAIR DONE U.A.T!!! -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Searching Device -- Found -- MODAL : GT-I9063T -- MANUFUCTURER : samsung -- ANDROID VERSION : 4.2.2 -- CPU : armeabi-v7a -- CHIPSET : java -- HARDWARE : java_ss_baffinlite -- SERIAL NO. : RX1F501GH9W -- SOFT VERSION : I9063TVJUAOL1 -- BUILD DATE : Wed Dec 2 00:30:46 KST 2015 -- BUILD TAGS : release-keys -- COUNTRY CODE : Brazil -- Checking Root Status !! -- Rooted -- Su Binararies : 3.43 -- Writting imei please wait... -- Reading Old IMEI -- IMEI 1 : 352********** -- IMEI 2 : 352********** -- Reading Data.... : Done -- New Imei to Write -- IMEI 1 : 35455********* -- IMEI 2 : 35455********* -- Writting IMEI : Done -- Rebooting Phone..... |
04-21-2018, 00:39 | #1425 (permalink) |
Freak Poster Join Date: May 2016 Location: BRAZIL
Member: 2578528 Status: Offline Thanks Meter: 139 | Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6580 Software Version : 0000 Hardware Version : 00CA Ram info. : 0xFD65800000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 8 seconds |
The Following 2 Users Say Thank You to marcelofigado For This Useful Post: |
