04-09-2018, 22:58 | #1384 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | FRP ZE553KL BT adb Checking Current Version Current Version OK Checking User Login User Login OK. Searching Device - Fastboot Device Found -- Reading Device Info. -- Version : 0.5 -- Product : MSM8953 -- Serial No : H3AZB10042376PZ Sending Data : Done Executing Exploit : Done Switching Device to Adb Mode Please Check device screen Allow Adb Authorization if Prompted. Waiting for Device to Connect Again Device Found MODAL : ZE553KL MANUFUCTURER : asus ANDROID VERSION : 7.1.1 CPU : arm64-v8a HARDWARE : qcom BUILD DATE : 2017年 12月 15日 星期五 20:34:02 BUILD TAGS : release-keys Checking Root Status !! Not Rooted Resetting Frp Please wait... Frp Reset done Elapsed Time : 0 minutes - 4 seconds |
The Following User Says Thank You to paulo pessoa For This Useful Post: |
04-10-2018, 09:30 | #1385 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Samsung J3(6) (j320f) network unlock done -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. Searching Device Device Found Selected Port : COM593 : SAMSUNG Mobile USB Modem #354 [ Port @115200] Selected Model : SM-J320F Reading Device Info... Model : SM-J320F Software Ver. : J320FXXU0AQJ1 : J320FOXX0AQI3 : J320FXXU0AQI1 : J320FXXU0AQJ1 Hardware Ver. : J320FXXU0AQJ1 : J320FOXX0AQI3 : J320FXXU0AQI1 : J320FXXU0AQJ1 Serial Number : RV8JB1VNAVY Base : SM-N900 PRD : SM-J320FZDDTPH);;OMCCODE( Unique Number : CQN004E5E9A67B4 IMEI : 353751095059342 Conection Type : AT,MTP Unlocking Please wait ... Unlock Done !! Rebooting Device... if not reboot please do it manually. if ask Unlock code Please Put 00000000 or 11111111 |
The Following 2 Users Say Thank You to sajid01913 For This Useful Post: |
04-10-2018, 19:21 | #1386 (permalink) |
Junior Member Join Date: Aug 2015 Location: Hurghada, Egypt Age: 34
Member: 2442876 Status: Offline Thanks Meter: 6 | Post All Successfully Repaired Phones by Uni-Android Tool TECNO WX3 RESET FRP DONE IN 6SEC Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6580 Software Version : 0000 Hardware Version : 00CA Ram info. : 0xFD65800000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 6 seconds |
The Following User Says Thank You to eng.hass.hs For This Useful Post: |
04-11-2018, 09:50 | #1389 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Samsung J2 (j200h) Flash Done -- Selected Port : [COM400] -- BaudRate : [115200] -- Connecting Device... -- Device Found. -- Flash Process Started... -- Pit Backup created in : C:\Program Files\Uni-Android\PIT_Backup\Samsung_Pit\_144702965_Samsung_ pit.pit -- Processing : spl.img Please wait ..... -- Writting : spl.img -- Processing : sboot.bin Please wait ..... -- Writting : sboot.bin -- Processing : sboot2.bin Please wait ..... -- Writting : sboot2.bin -- Processing : boot.img Please wait ..... -- Writting : boot.img -- Processing : recovery.img Please wait ..... -- Writting : recovery.img -- Processing : system.img Please wait ..... -- Writting : system.img -- Processing : SPRDCP.img Please wait ..... -- Writting : SPRDCP.img -- Processing : SPRDDSP.img Please wait ..... -- Writting : SPRDDSP.img -- Processing : cache.img Please wait ..... -- Writting : cache.img -- Processing : hidden.img Please wait ..... -- Writting : hidden.img -- All Done.. -- Rebooting Device To Normal Mode.. -- Elapsed Time : 00:02:02.85 |
The Following User Says Thank You to sajid01913 For This Useful Post: |
04-11-2018, 09:54 | #1390 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Samsung J2 Factory reset Done -- Searching Device -- Device Found -- Selected Port : [ COM271 : SAMSUNG Mobile USB Modem #147 ] -- BaudRate : [ 115200 ] -- Factory Resetting -- Factory Reset done. -- Rebooting Device -- All Done |
04-11-2018, 19:52 | #1391 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Jamaica Age: 38
Member: 441875 Status: Offline Thanks Meter: 24 | Huawei Union Y538 Unlock Huawei Union Y538 from Boost Mobile unlocked.. Phone must first be rooted.. (I used KingRook5.3.3 APK) Then go to the Huawei Tab on Uni-Android Tool, go to the Qualcomm tab. Select unlock and click do selected Job. Code: -- Searching Device -- Found -- MODAL : Y538 -- MANUFUCTURER : Huawei -- ANDROID VERSION : 5.1.1 -- CPU : armeabi-v7a -- HARDWARE : qcom -- BUILD DATE : Sat Oct 24 18:57:34 CST 2015 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : 3.79 -- Operation : HUAWEI UNLOCK -- Sending Data : Done -- Unlocking : Done |
The Following User Says Thank You to Bandolujamaican For This Useful Post: |
04-12-2018, 14:22 | #1392 (permalink) |
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | FRP MOTO E4 DONE Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Searching Device Device found Sending data Please wait ... Data Sent Successfully Chip Type : MT6737M Software Version : 0000 Hardware Version : 00CA Ram info. : 0xFD03350000 Resetting Frp Frp Reset Succeeded Elapsed Time : 0 minutes - 11 seconds |
04-12-2018, 14:47 | #1393 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Samsung J200F Network Unlock Done Just Select SM700H -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. Searching Device Device Found SELECTED PORT : COM597 : SAMSUNG Mobile USB Modem #358 [ Port @115200] Unlock Process Started .. Reading Device Info... Model : SM-J200F Software Ver. : J200FXXU1APE1 : J200FOJV1APE1 : J200FXXU1APE1 : J200FXXU1APE1 Hardware Ver. : J200FXXU1APE1 : J200FOJV1APE1 : J200FXXU1APE1 : J200FXXU1APE1 Serial Number : R58H55E874Y Base : SM-N900 PRD : SM-J200FZDDTHR Unique Number : C8G012265241E43 IMEI : 35709107********** Conection Type : AT,MTP Unlocking Device..... Unlock Done! Rebooting Device... if not reboot please do it manually. if ask Unlock code Please Put 00000000 or 11111111 |
