08-17-2022, 15:52 | #3706 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Tecno Spark 6 Air Dump Preloader Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Process : DUMP PRELOADER ==================================== Waiting for device... Device found MediaTek USB Port_V1632 (COM121) Mode : BootRom Port : COM121 Handshaking ... DONE Initializing : DONE Hw code: MT6765 - Helio P35/G35 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Protection disable ... DONE Prepairing data ... DONE Dumping preloader ... DONE Preloader saved as : C:\Program Files (x86)\UAT_PRO\Dumped_Preloader\preloader_ke6j_h6215_UATPRO_17-08-2022_12-05-38.bin UAT PRO : 143.01 | 17 - August - 2022 [ 12:05:38 PM ] Elapsed Time : 2 seconds 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Process : DUMP PRELOADER ==================================== Waiting for device... Device found MediaTek USB Port_V1632 (COM121) Mode : BootRom Port : COM121 Handshaking ... DONE Initializing : DONE Hw code: MT6765 - Helio P35/G35 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Protection disable ... DONE Prepairing data ... DONE Dumping preloader ... DONE Preloader saved as : C:\Program Files (x86)\UAT_PRO\Dumped_Preloader\preloader_ke6j_h6215_UATPRO_17-08-2022_12-05-38.bin UAT PRO : 143.01 | 17 - August - 2022 [ 12:05:38 PM ] Elapsed Time : 2 seconds |
08-17-2022, 15:54 | #3707 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Tecno Spark 6 Air FRP Remove Done By UAT Pro Tecno Spark 6 Air FRP Remove Done By UAT Pro Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : By Model - Brand : Tecno - Model : Tecno Spark 6 Air KE6j - Process : Reset FRP ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek PreLoader USB VCOM_V1632 (Android) (COM112) Mode : PreLoader Port : COM112 Handshaking ... DONE Jumping to brom : DONE Searching device on brom port Device found MediaTek USB Port_V1632 (COM121) Mode : BootRom Port : COM121 Handshaking ... DONE Initializing : DONE Hw code: MT6765 - Helio P35/G35 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2018-06-14.16:55_443441 Drivers : MediaTek Inc. Driver Date : 01/22/2015 Driver Version : 3.0.1504.0 Handshaking : DONE Loading Preloader : DONE Booting device : DONE Chip name : [MT6765] Syncing with DA : DONE Identifying Hardware ID ... ==================================== ChipID : MT6765 Software Ver : 0000 Hardware Ver : CA00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0xC0000000 SRAM : 0x00040000 Storage : 0x0E91000000 ==================================== RAM Size : 3.000 GB SRAM Size : 256.000 KB Storage Size : 58.266 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 41 Searching FRP data... DONE Resetting FRP... USING ALGO - 1 Reset FRP DONE Please disconnect device and reboot it manually UAT PRO : 143.01 | 17 - August - 2022 [ 12:12:07 PM ] Elapsed Time : 5 seconds |
08-17-2022, 15:58 | #3708 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Huawei BNL-L21 Kirin-655 FRP Remove Done By UAT Pro Huawei BNL-L21 Kirin-655 FRP Remove Done By UAT Pro Code: Waiting for device on COM 1.0 Port ... Port : [COM195 : HUAWEI USB COM 1.0] Analyzing Please wait ... Checking device... Device Checking done ! Selected CPU : Kirin-655 Checking Integrity : Done Writing UAT_PRO 1 done Writing UAT_PRO 2 done Waiting fastboot device ... Device found Reading device Info ... Device Model : BLN-L21 Device Firmware : BLN-L21C432B382 Country : EUROPE / GLOBAL Key Version : huawei_key_v1 Serial Number : 7BQDU17106003223 Device IMEI : 862510033308680 FB LockState : UNLOCKED USER LockState : LOCKED Resetting FRP, please wait ... Frp reset successfuly done... The device will reboot and do factory reset UAT PRO : 142.02 | 14 - August - 2022 [ 3:15:32 PM ] Elapsed Time : 5 seconds |
08-17-2022, 16:00 | #3709 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Huawei TRT-LX2 (Enjoy 7 Plus) Remove Done By UAT Pro Huawei TRT-LX2 (Enjoy 7 Plus) Remove Done By UAT Pro Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : TRT-LX2 (Enjoy 7 Plus) - Process : Reset FRP ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM85 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0B6000 | Snapdragon 435 BLOCK_ID_S : 991F11F7 BLOCK_ID_H : 1OP814066QN4PNQO8N2NS16029S34QO8 BLOCK_ID_H : 30558Q1796OQQ6SS028QON16OS1NR664 Executing boot : Done Configuring : Done Reading Parts : Done Partition Count : 60 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8937] Userdata : Encrypted Searching FRP Data.... Frp data found Resetting frp.... Reset frp success UAT PRO : 143.01 | 17 - August - 2022 [ 1:47:55 PM ] Elapsed Time : 8 seconds |
08-20-2022, 10:12 | #3710 (permalink) | |
Product Supporter Join Date: Sep 2016 Location: Pakistan
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,295 | Xiaomi REDMI NOTE 5A Prime MI Account Reset Done 1Click UAT PRO Xiaomi REDMI NOTE 5A Prime MI Account Reset Done 1Click .:: UAT PRO ::. Quote:
08-23-2022, 09:23 | #3711 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Samsung A127F FRP Remove Done By UAT Pro Samsung A127F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM88 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-A127F Country : BKD SW Version : A127FXXU5BVF2/A127FODM5BVF2/A127FXXU5BVF2/A127FXXU5BVF2 HW Version : A127FXXU5BVF2 MNC : 02,01 MCC : 470,470 Serial : R58R820TCAJ IMEI : 350816950184254 Unqiue Code : CDV007C78CC5368 Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-A127F Manufucture : samsung Android Version : 12 CPU : arm64-v8a Platform : exynos850 Hardware : exynos850 Board : exynos850 Bootloader : A127FXXU5BVF2 USB Config : mtp,adb User : dpi Baseband : A127FXXU5BVF2,A127FXXU5BVF2 Display ID : SP1A.210812.016.A127FXXU5BVF2 Build ID : SP1A.210812.016 PDA : A127FXXU5BVF2 SIM State : LOADED,LOADED Product Code : SM-A127FZBHBKD Soft Version : A127FXXU5BVF2 Build Date : Wed Jun 8 15:03:06 KST 2022 Build Tags : release-keys Country Code : Bangladesh Network Type : LTE,LTE SIM Operator : Robi,GramenPhone LCD Density : 300 Data Encryption : encrypted Device IMEI : Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 143.01 | 18 - August - 2022 [ 9:29:25 PM ] Elapsed Time : 10 seconds |
08-23-2022, 09:25 | #3712 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Samsung A505F FRP Remove Done By UAT Pro Samsung A505F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM86 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-A505F Country : BKD SW Version : A505FDDS9CVF3/A505FODM9CVB1/A505FXXS9CVF3/A505FDDS9CVF3 HW Version : A505FDDS9CVF3 MNC : 03,01 MCC : 470,470 Serial : R28M41RPYLK IMEI : 354465103431158 Unqiue Code : CE0419344DD1882C047E Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-A505F Manufucture : samsung Android Version : 11 CPU : arm64-v8a Platform : exynos9610 Hardware : exynos9610 Board : exynos9610 Bootloader : A505FDDS9CVF3 USB Config : mtp,adb User : dpi Baseband : A505FXXS9CVF3,A505FXXS9CVF3 Display ID : RP1A.200720.012.A505FDDS9CVF3 Build ID : RP1A.200720.012 PDA : A505FDDS9CVF3 SIM State : LOADED,LOADED Product Code : SM-A505FZKDBKD Soft Version : A505FXXS9CVF3 Build Date : Tue Jun 7 13:11:32 KST 2022 Build Tags : release-keys Country Code : Bangladesh Network Type : LTE,HSUPA SIM Operator : Banglalink,GramenPhone LCD Density : 420 Data Encryption : encrypted Device IMEI : 354465103431158 Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 143.01 | 17 - August - 2022 [ 11:53:08 PM ] Elapsed Time : 10 seconds |
08-23-2022, 09:33 | #3713 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Samsung M215F FRP Remove Done By UAT Pro Samsung M215F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM3 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-M215F Country : BKD SW Version : M215FXXS2BVB7/M215FODM2BUI1/M215FDDS2BVB7/M215FXXS2BVB7 HW Version : M215FXXS2BVB7 Serial : R58N74VRRPV IMEI : 358610130379195 Unqiue Code : CE0320439CEA21CB3F7E Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-M215F Manufucture : samsung Android Version : 11 CPU : arm64-v8a Platform : exynos9611 Hardware : exynos9611 Board : exynos9611 Bootloader : M215FXXS2BVB7 USB Config : mtp,adb User : dpi Baseband : M215FDDS2BVB7,M215FDDS2BVB7 Display ID : RP1A.200720.012.M215FXXS2BVB7 Build ID : RP1A.200720.012 PDA : M215FXXS2BVB7 SIM State : ABSENT,ABSENT Product Code : SM-M215FZBGBKD Soft Version : M215FDDS2BVB7 Build Date : Fri Feb 25 15:18:06 KST 2022 Build Tags : release-keys Country Code : Bangladesh Network Type : Unknown,Unknown LCD Density : 420 Data Encryption : encrypted Device IMEI : 358610130379195 Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 143.02 | 20 - August - 2022 [ 10:01:57 PM ] Elapsed Time : 5 seconds |
08-23-2022, 09:42 | #3714 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Oppo A71 (CPH1717) Password+FRP Remove Done By UAT Pro Oppo A71 (CPH1717) Password+FRP Remove Done By UAT Pro Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : By Model - Brand : OPPO - Model : Oppo A71 (CPH1717) - Process : Format | Factory Reset ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek PreLoader USB VCOM_V1632 (Android) (COM95) Mode : Meta Port : COM95 Handshaking ... DONE Jumping to brom : DONE Searching device on brom port Device found MediaTek USB Port_V1632 (COM121) Mode : BootRom Port : COM121 Handshaking ... DONE Initializing : DONE Hw code: MT6755 - Helio P10/P15/P18 Hw sub code: 8A00 Hw version: CB00 Sw version: 0001 Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2017-11-09.13:17_393798 Drivers : MediaTek Inc. Driver Date : 01/22/2015 Driver Version : 3.0.1504.0 Handshaking : DONE Loading Preloader : DONE Booting device : DONE Chip name : [MT6755] Syncing with DA : DONE Identifying Hardware ID ... ==================================== ChipID : MT6750 Software Ver : 0001 Hardware Ver : CB00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0xC0000000 SRAM : 0x00040000 Storage : 0x03A4A00000 ==================================== RAM Size : 3.000 GB SRAM Size : 256.000 KB Storage Size : 14.572 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 37 Reading system Information... Model : CPH1717 Hardware : full_oppo6750_17351 Android Ver. : 7.1.1 Android OS : Nougat CPU : arm64-v8a Platform : mt6750 Display id : CPH1717EX_11_A.28_200701 Build Date : Wed Jul 1 20:11:21 CST 2020 Build id : N4F26M Security Patch : 2019-10-05 Brand : OPPO Manufacturer : OPPO Product : oppo6750_17351 Local lang. : en-US Carrier : unknown GsmVersion : 7.1_r3 Searching for required data... DONE Formatting device ... DONE All successfully done Please disconnect device and reboot it manually If device stuck on Logo, please use recovery to wipe it and reboot UAT PRO : 143.02 | 20 - August - 2022 [ 4:42:41 PM ] Elapsed Time : 16 seconds |
08-23-2022, 09:45 | #3715 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Oppo A16 FRP Remove Done By UAT Pro Oppo A16 FRP Remove Done By UAT Pro Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek PreLoader USB VCOM_V1632 (Android) (COM47) Mode : Meta Port : COM47 Handshaking ... DONE Jumping to brom : DONE Searching device on brom port Device found MediaTek USB Port_V1632 (COM58) Mode : BootRom Port : COM58 Handshaking ... DONE Initializing : DONE Hw code: MT6765 - Helio P35/G35 Hw sub code: 8A00 Hw version: CA00 Sw version: 0000 Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2020-11-03.22:07_536568 Drivers : MediaTek Inc. Driver Date : 01/22/2015 Driver Version : 3.0.1504.0 Handshaking : DONE Loading Preloader : DONE Booting device : DONE Chip name : [MT6765] Syncing with DA : DONE Identifying Hardware ID ... ==================================== ChipID : MT6765 Software Ver : 0000 Hardware Ver : CA00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0x100000000 SRAM : 0x0003A000 Storage : 0x0E91000000 ==================================== RAM Size : 4.000 GB SRAM Size : 232.000 KB Storage Size : 58.266 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 48 Searching FRP data... DONE Resetting FRP... USING ALGO - 1 Reset FRP DONE Please disconnect device and reboot it manually UAT PRO : 143.01 | 17 - August - 2022 [ 7:34:54 PM ] Elapsed Time : 6 seconds |
08-23-2022, 12:10 | #3716 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Kumasi,Ghana
Member: 2496301 Status: Offline Thanks Meter: 41 | Waiting for MTP port ... Device found Port : [ COM16 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-P615N Country : KOO SW Version : P615NKOS4DUL5/P615NKOO4DUL5/P615NKOS4DUL5/P615NKOS4DUL5 HW Version : P61********L5 Serial : R5********XM IMEI : 35***********99 Unqiue Code : CE0***************7E Connection : AT,MTP Read Info done Enabling ADB... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for ADB device ... Device found Model: SM-P615N Manufacturer : Samsung Android Version: 11 CPU : arm64-v8a Platform : exynos9611 Hardware : exynos9611 Board : exynos9611 Bootloader : P61********L5 USB Config : MTP,ADB User : dpi Baseband : P61********L5 Display ID : RP1A.200720.012.P615NKOS4DUL5 Build ID : RP1A.200720.012 PDA : P615NKOS4DUL5 SIM State : ABSENT Soft Version : P615NKOS4DUL5 Build Date: Wed Dec 22 10:12:00 KST 2021 Build Tags : release-keys Country Code: KOREA Network Type: Unknown LCD Density : 240 Data Encryption : Encrypted Device IMEI: 35**********99 Checking Root: Not Rooted Resetting FRP please wait ... Reset FRP done UAT PRO : 143.02 | 23 - August - 2022 [ 1:53:23 pm ] Elapsed Time: 9 seconds GALAXY TAB S6 LITE |
08-23-2022, 12:10 | #3717 (permalink) |
08-24-2022, 09:46 | #3718 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Huawei DUB-LX1 (Y7 2019) FRP Remove Done By UAT Pro Huawei DUB-LX1 (Y7 2019) FRP Remove Done By UAT Pro Code: 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Huawei - Model : DUB-LX1 (Y7 2019) - Process : Reset FRP ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM5 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0A9000 | Snapdragon 625 BLOCK_ID_S : 1E5D255B BLOCK_ID_H : 1OP814066QN4PNQO8N2NS16029S34QO8 BLOCK_ID_H : 30558Q1796OQQ6SS028QON16OS1NR664 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 29.12 GB Userdata : 24.53 GB Partition Count : 57 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 16384 Max_Payload_Size_Supp. : 16384 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8953] Userdata : Encrypted Reading Device Information... Android Ver. : 8.1.0 CPU : arm64-v8a Android OS : Oreo Display id : System 8.2.0.036(2E2Y) Build Date : Thu Aug 12 15:30:59 CST 2021 Build id : OPM1.171019.011 Security Patch : 2020-09-01 Manufacturer : unknown Local lang. : en-US Searching FRP Data.... Frp data found Resetting frp.... Reset frp success UAT PRO : 143.02 | 24 - August - 2022 [ 2:13:42 PM ] Elapsed Time : 5 seconds |
08-24-2022, 12:50 | #3719 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Samsung A750F FRP Remove Done By UAT Pro Samsung A750F FRP Remove Done By UAT Pro Code: Waiting for MTP port ... Device found Port : [ COM106 : SAMSUNG Mobile USB Modem ] Reading device info. ... Brand : Samsung Electronics Co., Ltd. Model : SM-A750F Country : BRUNEI SW Version : A750FXXU4CTBC/A750FODM4CTBC/A750FNXXU4CTBA/A750FXXU4CTBC HW Version : A750FXXU4CTBC MNC : 01,03 MCC : 470,470 Serial : RZ8KA2F0RMF IMEI : 351578103889853 Unqiue Code : CCU006DF3BA9F95 Connection : AT,MTP Read Info done Enabling ADB .... ADB Enabled done Please check confirmation dialog on your device screen and allow it Waiting for adb device ... Device found Model : SM-A750F Manufucture : samsung Android Version : 10 CPU : arm64-v8a Platform : exynos7885 Hardware : exynos7885 Board : exynos7885 Bootloader : A750FXXU4CTBC USB Config : mtp,adb User : dpi Baseband : A750FNXXU4CTBA,A750FNXXU4CTBA Display ID : QP1A.190711.020.A750FXXU4CTBC Build ID : QP1A.190711.020 PDA : A750FXXU4CTBC SIM State : LOADED,LOADED Product Code : SM-A750FZBDBNG Serial No. : RZ8KA2F0RMF Soft Version : A750FNXXU4CTBA Build Date : Fri Feb 28 21:49:44 KST 2020 Build Tags : release-keys Country Code : Bangladesh Network Type : LTE,LTE SIM Operator : GramenPhone,Banglalink LCD Density : 420 Data Encryption : encrypted Device IMEI : 351578103889853 Checking Root : Not Rooted Resetting frp please wait ... Reset frp done UAT PRO : 143.02 | 24 - August - 2022 [ 3:32:12 AM ] Elapsed Time : 7 seconds |
