11-21-2021, 20:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Redmi Note 8 (ginkgo) Bootloader unlock problem |
02-08-2022, 13:29 | #2 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | After unlocking bootloader only, I see that phone has lost IMEI numbers, how do I fix them? Does UAT create any backup before unlocking bootloader?? 1. Power off device 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Xiaomi - Model : Redmi Note 8 (Ginkgo) - Process : Bootloader Unlock | Xiaomi ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM3 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E0A0100 | Snapdragon 665 BLOCK_ID_S : 63385CCE BLOCK_ID_H : 6OROR8318N1236QO9O56531518552889 BLOCK_ID_H : QR4R0PN69426P2P9S9803RP4Q24PQN91 Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 58.24 GB Userdata : 48.95 GB Partition Count : 87 Drivers : Qualcomm Technologies, Inc. Driver Version : 08/02/2017,2.1.2.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 16384 Max_Payload_Size_Supp. : 16384 Max_XML_Size : 4096 Version : 1 Date_Time : Jul 3 2019 - 22:23:56 Userdata : Encrypted Prepairing bootloader unlock data ... Data prepratition done Patching data please wait ... Data patching done Writing bootloader unlock data ... Write data done Rebooting device into fastboot mode If device does not reboot into fastboot, please do it manually Waiting fastboot device ... Device found Reading fastboot Information ... Product : laurel_sprout Secure : yes Serial : 127970760013 Download : 804276224 Checking bootloader status ... Bootloader is locked Unlocking bootloader ... Bootloader Unlock done UAT PRO : 136.01 | 05 - February - 2022 [ 17:20:08 ] Elapsed Time : 34 seconds |
02-08-2022, 14:07 | #3 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,539 | Quote:
Yes It does , just check your device fastboot info. it is showing Product : laurel_sprout but not Gingko , After bootloader unlock Please flash Global Firmware and check fastboot info. | |
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
02-08-2022, 17:27 | #4 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | By checking with the IMEI it is Redmi Note 8 Ginkgo, but laurel_sprout seems to be Xiaomi Mi A3, so this one is not Mi A3 at all, on ly if during the MI account reset by UMT or UAT I forget how I removed if it was touched. As you see I am struggling with this phone since many months cause MI account is returning back, and at the first post you can see at that time UAT was not able to Unlock bootloader, but now with latest updates yes. |
