01-04-2022, 10:44 | #1 (permalink) |
Major Poster Join Date: Dec 2015
Member: 2496788 Status: Offline Thanks Meter: 36 | Redmi Y2 Flasing Done UAT PRO Tool 2. Press and hold volume up + volume down insert usb cable 3. In some case requires special edl cable or test points 4. Install Qualcomm drivers if needed ==================================== - Connection : EDL - Method : By Model - Brand : Xiaomi - Model : Redmi Y2 - Process : Flash ==================================== Waiting for QDLoader port ... Port found Device on Port : [ COM20 : Qualcomm HS-USB QDLoader 9008 ] Analyzing Sahara please wait ... HW_ID : 0001E064000 | Snapdragon 625 BLOCK_ID_S : 716EAB33 BLOCK_ID_H : 02603RNS6369Q23SQ7O8650RPR9QO63N BLOCK_ID_H : 362N53NP119N0237N470S8SS3958Q84N Executing boot : Done Configuring : Done Reading Parts : Done Capacity : 29.12 GB Userdata : 23.37 GB Partition Count : 57 Drivers : Qualcomm Technologies, Inc. Driver Version : 05/29/2019,2.1.3.7 MEM_TYPE : eMMC Max_Payload_Size_InBytes : 1048576 Max_Payload_Size_Supp. : 1048576 Max_Bytes : 4096 Max_XML_Size : 4096 Version : 1 Target_Name : [MSM 8953] Userdata : Encrypted Reading Device Information... Model : Redmi S2 Android Ver. : 9 CPU : armeabi-v7a Software : Android9_12 Android OS : Pie MIUI Version : V12 MIUI Code : 10 Display id : PKQ1.181203.001 Build Date : Thu Sep 24 20:47:30 WIB 2020 Build id : PKQ1.181203.001 Security Patch : 2020-09-01 Brand : xiaomi Manufacturer : Xiaomi Product : ysl Emmc Size : 16GB Device Mod : ysl_global Local lang. : en-GB Writing : [config] ... config.bin ... Done Writing : [lksecapp] ... lksecapp.mbn ... Done Writing : [lksecappbak] ... lksecapp.mbn ... Done Writing : [devcfg] ... devcfg.mbn ... Done Writing : [devcfgbak] ... devcfg.mbn ... Done Writing : [rpm] ... rpm.mbn ... Done Writing : [rpmbak] ... rpm.mbn ... Done Writing : [sbl1] ... sbl1.mbn ... Done Writing : [sbl1bak] ... sbl1.mbn ... Done Writing : [cmnlib] ... cmnlib_30.mbn ... Done Writing : [cmnlibbak] ... cmnlib_30.mbn ... Done Writing : [cmnlib64] ... cmnlib64_30.mbn ... Done Writing : [cmnlib64bak] ... cmnlib64_30.mbn ... Done Writing : [keymaster] ... keymaster64.mbn ... Done Writing : [keymasterbak] ... keymaster64.mbn ... Done Writing : [aboot] ... emmc_appsboot.mbn ... Done Writing : [abootbak] ... emmc_appsboot.mbn ... Done Writing : [tz] ... tz.mbn ... Done Writing : [tzbak] ... tz.mbn ... Done Writing : [dsp] ... adspso.bin ... Done Writing : [splash] ... splash.img ... Done Writing : [mdtp] ... mdtp.img ... Done Writing : [boot] ... boot.img ... Done Writing : [recovery] ... recovery.img ... Done Writing : [modem] ... NON-HLOS.bin ... Done Writing : [cache] ... cache.img ... Done Writing : [cust] ... cust.img ... Done Writing : [vendor] ... vendor.img ... Done Writing : [system] ... system.img ... Done Writing : [userdata] ... userdata.img ... Done Writing : [PrimaryGPT] ... gpt_main0.bin ... Done Writing : [BackupGPT] ... gpt_backup0.bin ... Done Searching frp data.... FRP data found Resetting FRP.... Reset FRP success Writing patch0 : Done Write firmware successfully done. All process done... UAT PRO : 135.02 | 04 - January - 2022 [ 15:05:14 ] Elapsed Time : 3 minutes 58 seconds GSM Rakesh |
The Following 3 Users Say Thank You to sagarbhaiya For This Useful Post: |
