11-14-2022, 09:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Cavite,Philippines
Member: 710668 Status: Offline Thanks Meter: 121 | Tecno spark 8c 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Process : DUMP PRELOADER ==================================== Waiting for device... Device found MediaTek PreLoader USB VCOM_V1632 (Android) (COM21) Mode : PreLoader Port : COM21 Handshaking ... DONE Crashing preloader : DONE Searching device on brom port Device found MediaTek PreLoader USB VCOM_V1632 (Android) (COM21) Mode : PreLoader Port : COM21 Device failed to be on brom port |
11-14-2022, 09:27 | #2 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,532 | Quote:
You have connected device on preloader port .. and If force to brom and even Volume keys does not bring device on MTK USB Port [brom mode] Then you need to use test points. | |
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
11-15-2022, 02:46 | #3 (permalink) | |
Member: 710668 Status: Offline Thanks Meter: 121 | Quote:
what about the model is it necessary coz the model is not listed in option list??! for the meantme can we use mtk base according to its cipset? | |
