10-11-2021, 14:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Xiaomi Redmi 9 M2004J19G FRP remove done Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Xiaomi Model : Redmi 9 (Cattail) Process : Read Info. ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek USB Port (COM17) Mode : BootRom Port : COM17 Handshaking ... DONE Hw code: 0x0707 - [MT6768] - Helio P65/G85 Hw sub code: 0x8A00 Hw version: 0xCA00 Sw version: 0x0000 Sl auth: Yes Da auth: Yes Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2020/07/07.10:10_513994 Handshaking : DONE Loading Preloader : DONE Connecting to Brom : DONE Chip name : [MT6768] Sending DA Download-Agent : ACCEPTED Identifying Hardware ID ... ==================================== ChipID : MT6768 Software Ver : 0000 Hardware Ver : CA00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0x100000000 SRAM : 0x00070000 Storage : 0x0E91000000 ==================================== RAM Size : 4.000 GB SRAM Size : 448.000 KB Storage Size : 58.266 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 48 Reading system Information... frp remove done Code: 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== Connection : Flash Mode Method : By Model Brand : Xiaomi Model : Redmi 9 (Cattail) Process : Reset FRP ==================================== Authenticating ... DONE Initializing ... DONE ==================================== Waiting for device ... Device found MediaTek USB Port (COM17) Mode : BootRom Port : COM17 Handshaking ... DONE Hw code: 0x0707 - [MT6768] - Helio P65/G85 Hw sub code: 0x8A00 Hw version: 0xCA00 Sw version: 0x0000 Sl auth: Yes Da auth: Yes Watchdog disable ... DONE Protection disable ... DONE Preparing Download Agent ... DA Version : MTK_AllInOne_DA_v3.3001.2020/07/07.10:10_513994 Handshaking : DONE Loading Preloader : DONE Connecting to Brom : DONE Chip name : [MT6768] Sending DA Download-Agent : ACCEPTED Identifying Hardware ID ... ==================================== ChipID : MT6768 Software Ver : 0000 Hardware Ver : CA00 Secure Ver : 00 BootLdr Ver : 00 Ext RAM : 0x100000000 SRAM : 0x00070000 Storage : 0x0E91000000 ==================================== RAM Size : 4.000 GB SRAM Size : 448.000 KB Storage Size : 58.266 GB Storage Type : EMMC ==================================== Getting partition details : DONE Partition count : 48 Searching FRP data... DONE Resetting FRP... USING ALGO - 1 Reset FRP DONE Please disconnect device and reboot it manually DONE BY UAT MTK MODULE : 4.02 Elapsed Time : 00:00:02 |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
