01-03-2020, 17:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mongarrasco
Member: 107027 Status: Offline Thanks Meter: 269 | about ONE CLICK EASY DOWNGRADE i've a bla-l09 ver. 9.0.0.206 c432, need to downgrade, so i can connect by tp, flash bla_downgrade_board directly and make all the operation? after must write back same firmware as 9.0.0.206 c432 version? br ss |
01-04-2020, 16:02 | #2 (permalink) |
Member: 107027 Status: Offline Thanks Meter: 269 | so....all solved! flashed downgrde file HDE Flasher 0.0.0.117 user:xxxxxxx Looking for a device in force upgrade mode Device detected: COM35: HUAWEI USB COM 1.0 (COM35) 04/01/2020 13:27:28 Starting to write device in FASTBOOT mode... File to update: D:\Cellmania\HDE\board files\BLA-Downgrade-Board-1.0.0.56-8.1.0_r1.dgtks Device detected: COM35: HUAWEI USB COM 1.0 (COM35) Process identifier:21885959 Writing bootloader... Step 1... Step 2... Step 3... Waiting for device REMOVAL/INSERTION... USB Device REMOVAL Type: @oem181.inf,%qcomdevice00%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 5&26610437&0&2 USB Device INSERTION Type: @oem96.inf,%singleadbinterface%;Alcatel ADB Interface VidPid: VID_18D1&PID_D00D Instance id: GAB7N17B18003864 Waiting for fastboot device... Device found: GAB7N17B18003864 Looking for a device in fastboot mode Device found: GAB7N17B18003864 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:GAB7N17Bxxxxxxxx IMEI:86621803xxxxxxxx IMEI1:8662180xxxxxxxx MEID:A0000082xxxxxx Build number: :BLA-L09 9.0.0.206(C432E4R1P11) Model: BLA-L09 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Erasing ver .. . Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing ptable partition PTABLE partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing xloader partition XLOADER partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing fastboot partition FASTBOOT partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing vector partition VECTOR partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing kernel partition KERNEL partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing ramdisk partition RAMDISK partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing hhee partition HHEE partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing hdcp partition HDCP partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing vbmeta partition VBMETA partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing odm partition ODM partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing recovery_ramdisk partition RECOVERY_RAMDISK partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing recovery_vendor partition RECOVERY_VENDOR partition update ...OK Erasing cust partition Partition cust erased Erasing misc partition Partition misc erased Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Erasing cache partition Partition cache erased Writing cache partition CACHE partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing fw_lpm3 partition FW_LPM3 partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing hisee_img partition HISEE_IMG partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing hisee_fs partition HISEE_FS partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing fw_hifi partition FW_HIFI partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing teeos partition TEEOS partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing trustfirmware partition TRUSTFIRMWARE partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing sensorhub partition SENSORHUB partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing dts partition DTS partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing dto partition DTO partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing modem_fw partition MODEM_FW partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing modemnvm_update partition MODEMNVM_UPDATE partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing modemnvm_cust partition MODEMNVM_CUST partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing isp_firmware partition ISP_FIRMWARE partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing system partition sending sparse file 471494772 bytes Waiting for answer... send sparse file OK sending sparse file 463737796 bytes Waiting for answer... send sparse file OK sending sparse file 433480996 bytes Waiting for answer... send sparse file OK SYSTEM partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing vendor partition sending sparse file 464701952 bytes Waiting for answer... send sparse file OK sending sparse file 225149340 bytes Waiting for answer... send sparse file OK VENDOR partition update ...OK Erasing product partition Partition product erased Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing product partition PRODUCT partition update ...OK Erasing version partition Partition version erased Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing version partition VERSION partition update ...OK Erasing userdata partition Partition userdata erased Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Erasing userdata partition Partition userdata erased Writing userdata partition USERDATA partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing hibench_data partition HIBENCH_DATA partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing ufs_fw partition UFS_FW partition update ...OK Writing huawei_crc_check partition HUAWEI_CRC_CHECK partition update ...OK Writing splash2 partition SPLASH2 partition update ...OK Erasing bootfail_info partition Partition bootfail_info erased Erasing dfx partition Partition dfx erased Erasing rrecord partition Partition rrecord erased Erasing patch partition Partition patch erased Waiting for fastboot device... USB Device REMOVAL Type: @oem96.inf,%singleadbinterface%;Alcatel ADB Interface VidPid: VID_18D1&PID_D00D Instance id: GAB7N17B18003864 USB Device INSERTION Type: @oem96.inf,%singleadbinterface%;Alcatel ADB Interface VidPid: VID_18D1&PID_D00D Instance id: GAB7N17B18003864 Device found: GAB7N17B18003864 Waiting for OEM oeminfoerase-vendorcountry command ...OK Waiting for OEM oeminfoerase-devicemodel command ...OK Waiting for OEM oeminfoerase-ver command ...OK Waiting for OEM oeminfoerase-single_sim command ...OK USB Device REMOVAL Type: @oem96.inf,%singleadbinterface%;Alcatel ADB Interface VidPid: VID_18D1&PID_D00D Instance id: GAB7N17B18003864 Software written 04/01/2020 13:33:59 Writing device finished OK after phone start and we can repair imei, unlock, read bootloader code and others operations, don't forget to write model, vendor and country! after all flash with an android 8 firmware. that's all! many many thanks to @solgeo that assist me for all the procedure! br ss |
01-09-2020, 10:30 | #3 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Gemany Age: 41
Member: 9493 Status: Offline Thanks Meter: 9 | ... I have some Mate 10 Pro BLA-L09 I need to downgrade. I flashed BLA-Downgrade-Board-1.0.0.56-8.1.0_r1.dgtks from support after i put phone in Testpoint Mode. File was flashed correctly and phone booted up after the flash and I could repair country/vendor after. Then I flashed BLA-L09C_8.0.0.115(C432)_Firmware_Germany_Netherlands_ Italy_Switzerland_Nonspecific_Android_8.0.0_EMUI_8 .0.0_05014UYJ.APP and update_BLA-L09_8.0.0.115(C432)_hw_eu.APP via fastboot and upgrade mode. the phone got flashed without any error but it does not start after the update. Screen stays dark and when i connect phone to pc it is always in TP Mode (device manager shows HUAWEI USB COM 1.0) Phone was working before the downgrade. What am I doing wrong here? |
01-09-2020, 10:43 | #4 (permalink) | |
Member: 107027 Status: Offline Thanks Meter: 269 | Quote:
after board firmware write model, country, vendor, make direct unlock and read bootloader, if need imei also. when you make all and if you use hw eu, download and flash this firmware BLA-L29C 8.0.0.148(C432) report here br | |
The Following User Says Thank You to agentot For This Useful Post: |
01-09-2020, 11:41 | #5 (permalink) |
Member: 9493 Status: Offline Thanks Meter: 9 | ... Hello thanks for answer. Where did u get this file? I dont find it on support. Also I would need the hw eu cust file for the single sim (bla-l09) version of it |
