10-01-2021, 09:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 998040 Status: Offline Sonork: 100.151982 Thanks Meter: 33 | cannot restore whats the problem [info] Using LOCAL IPSW C:\Users\uer\Desktop\New folder\MFC_Watch5,1_7.6.2_18U80_n144sap_GPS_Restor e_40mm.ipsw [info] using cached version data [info] Found device in Normal mode [info] Gettting normal mode device ... [info] Identified device as Apple Watch S5, n144sap, Watch5,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.6.2 [data] Product Build: 18U80 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0016750a14d3002e [info] Getting ApNonce in normal mode... [data] 9C0C662D53A89153C98000982962CF354C00887DC85A667DF5 D7AA96EBD04F2B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in normal mode... [data] 56E523B8C6E69DA89E89E609EE1615D99C05BFDF [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [erro] Unable to get FirmwarePreflightInfo [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.) [warn] The specified firmware version is either unsigned or nonexistent. Signing might be stopped! [erro] tts>Unable to send TSS request [erro] Unable to get SHSH blobs for this device [done] Operation finished! [info] device disconnect... [info] device arrival... new |
