01-28-2022, 12:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Connecting to host instance 0 using TCP problem port 9430!WSA code: 10060 ? I try all the day: [info] Connection uses alternative backend [erro] Could not find device with ECID:10B428380610A6 in DFU mode! [info] Adding DFU rules... [info] Please reconnect your device and try again! [done] Operation finished! [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10060 - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. but no chance |
01-28-2022, 13:00 | #2 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | I installed win10 on this same PC but another SSD and checked the IP it is different. I didn't restarted the router or network at all. Same problems logging into Win10. Now I switched again into Windows 7 - same PC everything same, IP has changed totally different. It means that I can never use this paid software because of these restrictions. [erro] Error... [warn] Server did not respond properly! Other software functions might fail! Please check your internet connection and or firewall! [erro] Connecting to host instance 0 using TCP problem port 9430![erro] WSA code: 10060 - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. [erro] Server init state connect failed Yesterday I was working on this same PC that I have on the shop with MFC and flashed a Watch with DEMO version successfully.... Every PC restart changes my IP |
01-28-2022, 14:06 | #3 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | [info] device disconnect... [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [info] Current thread priority is 0x0 [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10060 - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. [erro] Please check conenction with server and make sure you account is activated! [erro] An error has occured! Aborting! [done] Operation finished! |
01-28-2022, 19:34 | #4 (permalink) |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | Connecting to host instance 0 using TCP problem port 9430!WSA code: 10060 this because your local internet connection not stable ! We have nothing to do for this ! thanks |
01-28-2022, 21:26 | #5 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Can you reset now my IP I am trying at home fast stable internet 200 MBps, and IP is IPv6. It is not normal to stop me from using whenever I want and I need this program that I bought. Why just you these restrictions? I never met such restrictions before. And for what I bought dongle? Does the dongle has same restrictions if I put it into USB port I want to work now, not when you like it after 24 hours |
