08-14-2018, 03:09 | #3 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2516243 Status: Offline Thanks Meter: 0 | [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\phu\Desktop\MFC_Watch3,4_15T567_4.3.1_n12 1bAP_GPS_Restore_42mm.ipsw [info] Loading version data from Apple Server [info] Updated version data. [info] Found device in Recovery mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.1 [data] Product Build: 15T567 Major: 15 [info] device serial number is FHLVHZ3DJ5X4 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 3507176487853862 [info] Getting ApNonce in recovery mode... [data] 0F1FCF9815877E493624072DC3FD9089FF52585B3D181D0A05 EC02867EFB771C [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 3757AFAED519F6BC75FC3C27750E68EA039700F3 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_15T567_4.3.1_n121bAP_GPS_Restore_42mm/048-11192-070.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Sending iBEC (727438 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.60.11 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8651 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-11278-070.dmg... [info] Sending RestoreRamDisk (83318476 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Sending RestoreDeviceTree (103646 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Sending RestoreKernelCache (13971372 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device bfe6e55e09a953dd1d7b5d15d512e295ae43715e has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 3507176487853862 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n121b.release.im4p... [info] Extracting DeviceTree.n121bap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 06896A10 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 093DF2D8 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [erro] Unable to receive message from FDR 06896A10 (-4). 0/2 bytes [info] Apple device disconnected! Restore with mfc dongle |
08-14-2018, 09:47 | #4 (permalink) |
Member: 2516243 Status: Offline Thanks Meter: 0 | Logs with itunes of mac 5:16:31.2145] restore-step-error = {0x11070635:"[0]D(failed to update device firmware)[1]D(ramrod firmware update failed)[2]D(update_swdhid: swd-flash-updater failed with error -10)"} [15:16:31.2145] restore-step-uptime = 351 [15:16:31.2145] restore-step-user-progress = 79 [15:16:31.2145] [08:16:28.0747-GMT]{5>8} CHECKPOINT BEGIN: RESTORED:[0x0647] cleanup_check_result [15:16:31.2145] restore-step-ids = {0x11030635:59;0x11031305:65;0x11030647:66} [15:16:31.2145] restore-step-names = {0x11030635:update_device_firmware;0x11031305:upda te_swdhid;0x11030647:cleanup_check_result} [15:16:31.2145] restore-step-uptime = 351 [15:16:31.2145] restore-step-user-progress = 79 [15:16:31.2145] [08:16:28.0759-GMT]{5>8} CHECKPOINT END: RESTORED:[0x0647] cleanup_check_result [15:16:31.2145] restore-step-ids = {0x11030635:59;0x11031305:65} [15:16:31.2145] restore-step-names = {0x11030635:update_device_firmware;0x11031305:upda te_swdhid} [15:16:31.2145] restore-step-uptime = 351 [15:16:31.2145] restore-step-user-progress = 79 [15:16:31.2145] [08:16:28.0767-GMT]{5>8} CHECKPOINT BEGIN: RESTORED:[0x0648] cleanup_send_final_status [15:16:31.2145] restore-step-ids = {0x11030635:59;0x11031305:65;0x11030648:67} [15:16:31.2145] restore-step-names = {0x11030635:update_device_firmware;0x11031305:upda te_swdhid;0x11030648:cleanup_send_final_status} [15:16:31.2145] restore-step-uptime = 351 [15:16:31.2145] restore-step-user-progress = 79 [15:16:31.2145] progress = 79 [15:16:31.2145] [15:16:31.2145] ==== end of device restore output ==== [15:16:31.2175] AMRAuthInstallDeletePersonalizedBundle [15:16:31.2270] <Restore Device 0x60000034e9c0>: Restore failed (result = -1) [15:16:31.2281] AMRestorePerformRestoreModeRestoreWithError failed with error: -1 [15:16:31.2283] Finished RestoreOS Restore Phase: Failed [15:16:31.2284] State Machine Dump, status:ERROR - [state:Recovery remaining-cycles:0] -> [state:RestoreOS remaining-cycles:0 (current state)] [15:16:31.2292] Changing state from 'Restoring' to 'Error' [15:16:31.2292] State is now set to error [15:16:31.2300] Restore completed, status:7 [15:16:31.2300] Restore Checkpoint Fingerprint: 1305.FFFF [15:16:31.2300] Failure Description: [15:16:31.2300] Depth:0 Code:-1 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: -1 [15:16:31.2300] Depth:1 Code:-1 Error:Failed to handle message type StatusMsg [15:16:31.2300] Depth:2 Code:-1 Error:failed to update device firmware [15:16:31.2300] Depth:3 Code:-1 Error:ramrod firmware update failed [15:16:31.2300] Depth:4 Code:7 Error:update_swdhid: swd-flash-updater failed with error -10 |
