03-13-2021, 04:11 | #1 (permalink) |
Junior Member Join Date: Feb 2009
Member: 976536 Status: Offline Thanks Meter: 1 | i can't relod ios S5 44mm Gps i already donwload many times signed firmware and always got this message, some help me pls thanks [info] Using LOCAL IPSW C:\Users\pauli\Downloads\MFC_Watch5,2_18S801_7.3_n 144bap_GPS_Restore_44mm (1).ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S5, n144bap, Watch5,2 [info] Extracting BuildManifest from ipsw [info] Device ecid (436666414) added! File C:\Users\pauli\Downloads\MFC_Watch5,2_18S801_7.3_n 144bap_GPS_Restore_44mm (1).ipsw not recognized by server! File size: 2791313226 Please check if the file you downloaded is complete! Aborting operation! Firmware file might be corrupt. Unable to extract BuildManifest from C:\Users\pauli\Downloads\MFC_Watch5,2_18S801_7.3_n 144bap_GPS_Restore_44mm (1).ipsw. [done] Operation finished! |
03-16-2021, 11:47 | #3 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2615439 Status: Offline Thanks Meter: 3 | Same problem. [info] Using LOCAL IPSW C:\Users\Arvuti\Downloads\MFC_Watch5,1_18S801_7.3_ n144sap_GPS_Restore_40mm(1).ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S5, n144sap, Watch5,1 [info] Extracting BuildManifest from ipsw File C:\Users\Arvuti\Downloads\MFC_Watch5,1_18S801_7.3_ n144sap_GPS_Restore_40mm(1).ipsw not recognized by server! File size: 2818586774 Please check if the file you downloaded is complete! Aborting operation! Firmware file might be corrupt. Unable to extract BuildManifest from C:\Users\Arvuti\Downloads\MFC_Watch5,1_18S801_7.3_ n144sap_GPS_Restore_40mm(1).ipsw. |
03-16-2021, 12:33 | #4 (permalink) |
Registered User Join Date: Nov 2007
Member: 632005 Status: Offline Thanks Meter: 1 | [info] Using LOCAL IPSW C:\Users\HAi HQ\Downloads\MFC_Watch4,1_18S801_7.3_n131sap_GPS_R estore_40mm (2).ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131sap, Watch4,1 [info] Extracting BuildManifest from ipsw [info] Device ecid (909705262) added! File C:\Users\HAi HQ\Downloads\MFC_Watch4,1_18S801_7.3_n131sap_GPS_R estore_40mm (2).ipsw not recognized by server! File size: 2819734453 Please check if the file you downloaded is complete! Aborting operation! Firmware file might be corrupt. Unable to extract BuildManifest from C:\Users\HAi HQ\Downloads\MFC_Watch4,1_18S801_7.3_n131sap_GPS_R estore_40mm (2).ipsw. [done] Operation finished! try to run the software as administrator NOT WORK |
