Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 01-18-2022, 12:10   #1 (permalink)
Member: 2485783
Thanks Meter: 8
Apple watch giving unknow erros
[info] Device present connection uses normal backend
[info] Connecting...
[info] Device present in DFU mode using normal backend
[erro] zip_fopen_index: device_map.plist
[erro] Could not open database file
[erro] Current DFU device (ChipId: 0x8004 BoardId: 24) does not exist in our database or data is incomplete!
[done] Operation finished!
Sent from my iPhone using Tapatalk
Old 01-18-2022, 12:48   #2 (permalink)
Member: 2485783
Thanks Meter: 8
Diag load have zip open issue
Old 01-18-2022, 13:16   #3 (permalink)
Member: 2277861
Thanks Meter: 206
Reinstall v3.9 , that's it !
as i test S3:
[info] Current thread priority is 0x0
[info] stage 1, heap grooming ...
[info] stage 2, aquired
[info] stage 3, exploit
[info] Uploading payload
[done] Device is now in pwned DFU Mode!
[info] Sending FirstStage
[info] Sending commands ...
[info] Sending DiagsStage
[info] Selected port: COM6
[info] Device is allready in Diag Mode on COM6
[info] Opening \\.\COM6 with baudrate 115200
[info] Opening successfull!
Old 01-18-2022, 13:17   #4 (permalink)
Member: 2485783
Thanks Meter: 8
as i test S3:
Are step by step guide for rewriting serial?
Old 01-18-2022, 13:19   #5 (permalink)
Member: 2277861
Thanks Meter: 206
Read https://forum.gsmhosting.com/vbb/f93...ftware-2974487
Old 01-18-2022, 13:25   #6 (permalink)
Member: 2485783
Thanks Meter: 8
I know how to. Just want the professional way to go about it. Cause series comes with SN, WIFI AND BT.
Old 01-18-2022, 13:31   #7 (permalink)
Member: 2485783
Thanks Meter: 8
as i test S3:
Getting this error after writing serial
Old 01-18-2022, 15:03   #8 (permalink)
Member: 2485783
Thanks Meter: 8
Unabled to pair everytime on MFc
always unable to pair but not the same with awrt
What's wrong?
Old 01-18-2022, 15:57   #9 (permalink)
Member: 2277861
Thanks Meter: 206
What's wrong?
You don't have to start with a new thread !
unable to pair issue ,please read the link above
Old 01-18-2022, 23:38   #10 (permalink)
Member: 785495
Thanks Meter: 6
I have had some issues with at least 3 Series 3 devices...and the problem was the SERIAL+BT+Wifi address...
When you have those issues and the hardware is OK, just try another serial combination and works just great!
Just give it a try and let us know.
The Following User Says Thank You to vinhidalgo For This Useful Post:
Old 01-19-2022, 08:12   #11 (permalink)
Member: 1144374
Thanks Meter: 64
And make reset after change SN an Mac adresses.
Page generated in 0.18222 seconds with 8 queries
