12-29-2023, 00:38 | #1 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Watch 5 is it possible to backup activation and restore same like old iPhones? I tried to load some Ramdisks here in MFC bust says Bootchain not found, and I have very little experience with this Code: [info] Found device in Normal mode [info] Gettting normal mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [info] changing mode from Normal to Recovery [info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\00008006000A65C822C3802E) [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ]) [info] device serial number is G99CPMCEMLTJ [warn] operation not defined! [done] Operation finished! [info] Using LATEST available file. [erro] We don't know firmware locations for device OS type! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [erro] Can't find MobileDeviceSoftwareVersionsByVersion dict in version data [erro] can't get URL for latest firmware [done] Operation finished! [info] Using local file D:\MFCBOX\iWatch Firmware\MFC_Watch5,1_20U502_9.6.3_n144sap_GPS_Restore_40mm.ipsw [erro] We don't know firmware locations for device OS type! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [info] Extracting BuildManifest from ipsw [data] Product Version: 9.6.3 [data] Product Build: 20U502 Major: 20 [info] device serial number is G99CPMCEMLTJ [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update the device without erasing user data. [info] Checking for required components... [info] Using ECID 000a65c822c3802e [info] Getting ApNonce in recovery mode... [data] CBCE03FB5EA3E1D63B86207A525ACD4A04626E9CA49B8E45576823EC9453BFE1 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 392D8D0BB5B686F21204012D8E407138C5CC4DB6 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] Unable to find component node for Cryptex1,SystemOS [info] Extracting filesystem... [info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ]) [erro] Device is in an invalid state [erro] Unable to find device ECID [done] Operation finished! |
12-29-2023, 00:47 | #2 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Managed to make it update without clearing userdata: Code: [info] Found device in Normal mode [info] Gettting normal mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [info] changing mode from Normal to Recovery [info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\00008006000A65C822C3802E) [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ]) [info] device serial number is G99CPMCEMLTJ [warn] operation not defined! [done] Operation finished! [info] Using LATEST available file. [erro] We don't know firmware locations for device OS type! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [erro] Can't find MobileDeviceSoftwareVersionsByVersion dict in version data [erro] can't get URL for latest firmware [done] Operation finished! [info] Using local file D:\MFCBOX\iWatch Firmware\MFC_Watch5,1_20U502_9.6.3_n144sap_GPS_Restore_40mm.ipsw [erro] We don't know firmware locations for device OS type! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [info] Extracting BuildManifest from ipsw [data] Product Version: 9.6.3 [data] Product Build: 20U502 Major: 20 [info] device serial number is G99CPMCEMLTJ [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update the device without erasing user data. [info] Checking for required components... [info] Using ECID 000a65c822c3802e [info] Getting ApNonce in recovery mode... [data] CBCE03FB5EA3E1D63B86207A525ACD4A04626E9CA49B8E45576823EC9453BFE1 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 392D8D0BB5B686F21204012D8E407138C5CC4DB6 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] Unable to find component node for Cryptex1,SystemOS [info] Extracting filesystem... [info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ]) [erro] Device is in an invalid state [erro] Unable to find device ECID [done] Operation finished! [erro] Usbmux could not find any device! [info] Please put the device in DFU mode and try again! [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ]) [warn] Operation aborted by user! [info] Using local file D:\MFCBOX\iWatch Firmware\MFC_Watch5,1_20U502_9.6.3_n144sap_GPS_Restore_40mm.ipsw [erro] We don't know firmware locations for device OS type! [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Database recognized as: Generation: Apple Watch S5 'A' Number Bootrom 3988.0.0.2.12 Bootrom A2092 Variant Watch5,1 FCC ID BCG-A2092 Internal Name N144sAP Identifier Watch5,1 Color Aluminium Gold Storage 40 GB Model MWRY2 [info] Extracting BuildManifest from ipsw [data] Product Version: 9.6.3 [data] Product Build: 20U502 Major: 20 [info] device serial number is G99CPMCEMLTJ [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update the device without erasing user data. [info] Checking for required components... [info] Using ECID 000a65c822c3802e [info] Getting ApNonce in recovery mode... [data] B8133B77797411BB488E0E231E8EF35A1767C2C98BC803F804DC9E36DA8A0FC5 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 61D371EB6CD58980F8E838A5B809250967E1C357 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] Unable to find component node for Cryptex1,SystemOS [info] Using cached file 'D:\MFCBOX\iWatch Firmware\MFC_Watch5,1_20U502_9.6.3_n144sap_GPS_Restore_40mm\097-48531-003.dmg' [info] Found ECID 000a65c822c3802e [info] Getting ApNonce in recovery mode... [data] B8133B77797411BB488E0E231E8EF35A1767C2C98BC803F804DC9E36DA8A0FC5 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 61D371EB6CD58980F8E838A5B809250967E1C357 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1182215 bytes)... [info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3D_SRNM:[G99CPMCEMLTJ]) [info] Device ecid 000a65c822c3802e disconnect detected! [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CPFM:03_SCEP:01_BDID:10_ECID:000A65C822C3802E_IBFL:3C_SRNM:[G99CPMCEMLTJ]) [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-8422.140.59 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10155 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1958115 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1937295 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Personalizing IMG4 component ANE... [info] Sending ANE (1771159 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Personalizing IMG4 component AOP... [info] Sending AOP (1608871 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Personalizing IMG4 component GFX... [info] Sending GFX (881535 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (17828 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Personalizing IMG4 component SCE... [info] Sending SCE (20157 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160603 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (33286 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (94379178 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (43088 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (3366288 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (14708216 bytes)... [info] Device ecid 000a65c822c3802e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-000A65C822C3802E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 16 [info] ChipID: 32774 [info] UniqueChipID: 2926660018208814 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [done] sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Updating NAND Firmware (58) [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [info] Getting firmware manifest from build identity [info] Personalizing IMG4 component LLB... [info] Personalizing IMG4 component AppleLogo... [info] Personalizing IMG4 component Dali... [info] Personalizing IMG4 component DeviceTree... [info] Personalizing IMG4 component RecoveryMode... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Personalizing IMG4 component iBoot... [info] Personalizing IMG4 component RestoreSEP... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [done] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1699 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49158 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4876 complete with code 0 [info] Checkpoint 4870 complete with code 0 [info] Checkpoint 4871 complete with code 0 [info] Checkpoint 4872 complete with code 0 [info] Checkpoint 4878 complete with code 0 [info] Checkpoint 4879 complete with code 0 [info] Checkpoint 4875 complete with code 0 [info] Checkpoint 4867 complete with code 0 [info] Checkpoint 4880 complete with code 0 [info] Checkpoint 4895 complete with code 0 [info] Updating SE Firmware (59) [info] About to send BuildIdentity Dict... [info] Sending BuildIdentityDict now... [done] sending BuildIdentityDict [info] About to send SE,UpdatePayload... [info] Sending SE,UpdatePayload now... [done] sending SE,UpdatePayload [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [done] sending FirmwareUpdater data [info] Checkpoint 4873 complete with code 0 [info] Unknown operation (79) [info] Checkpoint 4886 complete with code 0 [info] Checkpoint 1589 complete with code 0 [info] Checkpoint 1596 complete with code 0 [info] Checkpoint 5379 complete with code 0 [info] Checkpoint 4890 complete with code 0 [info] Checkpoint 4889 complete with code 0 [info] Requesting EAN Data (74) [info] Checkpoint 5380 complete with code 0 [info] Checkpoint 4884 complete with code 0 [info] Checkpoint 1640 complete with code 0 [info] Checkpoint 1597 complete with code 0 [info] Checkpoint 1647 complete with code 0 [info] Creating Protected Volume (67) [info] Checkpoint 1652 complete with code 0 [info] Checkpoint 1631 complete with code 0 [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [done] Done sending KernelCache [info] Installing kernelcache (27) [info] Checkpoint 3584 complete with code 0 [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [done] Done sending DeviceTree [info] Installing DeviceTree (61) [info] Checkpoint 3585 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [info] Getting firmware manifest from build identity [info] Personalizing IMG4 component LLB... [info] Personalizing IMG4 component AppleLogo... [info] Personalizing IMG4 component Dali... [info] Personalizing IMG4 component DeviceTree... [info] Personalizing IMG4 component RecoveryMode... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Personalizing IMG4 component iBoot... [info] Personalizing IMG4 component RestoreSEP... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [done] Done sending NORData [info] Checkpoint 3588 complete with code 0 [info] Checkpoint 3589 complete with code 0 [info] Checkpoint 3587 complete with code 0 [info] Checkpoint 1576 complete with code 0 [info] Fixing up /var (17) [info] Checkpoint 3840 complete with code 0 [info] Checkpoint 3841 complete with code 0 [info] Checkpoint 3842 complete with code 0 [info] Checkpoint 3844 complete with code 0 [info] Checkpoint 3849 complete with code 0 [info] Checkpoint 1613 complete with code 0 [info] Checkpoint 1694 complete with code 0 [info] Checkpoint 1595 complete with code 0 [info] Modifying persistent boot-args (25) [info] Checkpoint 1593 complete with code 0 [info] Checkpoint 1630 complete with code 0 [info] Checkpoint 1672 complete with code 0 [info] Checkpoint 1659 complete with code 0 [info] Checkpoint 5632 complete with code 0 [info] Checkpoint 1599 complete with code 0 [info] Checkpoint 1600 complete with code 0 [info] Checkpoint 1675 complete with code 0 [info] Checkpoint 1641 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1706 complete with code 0 [info] Checkpoint 1707 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1602 complete with code 0 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\00008006-000A65C822C3802E) |
