01-30-2021, 12:12 | #1 (permalink) |
Junior Member Join Date: Oct 2012 Location: india
Member: 1830731 Status: Offline Sonork: 100.1622769 Thanks Meter: 6 | iwatch s3 flashing error [info] Using LOCAL IPSW C:\Users\Harry\Downloads\MFC_Watch3,2_7.2_18S563_n 111bAP_GPS_Cellular_Restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111bap, Watch3,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.2 [data] Product Build: 18S563 Major: 18 [info] device serial number is G99X1C03J6GF [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0000f95c0c380026 [info] Getting ApNonce in recovery mode... [data] 71921C156F59DEEBA534E987DBCAA3455D9EBF640A0D602ACD A98A8500338513 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] E3F51FC8BBE83A6470D0998911BA3F24D0DF3B6B [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,2_7.2_18S563_n111bAP_GPS_Cellular_Resto re_42mm/038-82387-072.dmg' [info] Found ECID 0000f95c0c380026 [info] Getting ApNonce in recovery mode... [data] 71921C156F59DEEBA534E987DBCAA3455D9EBF640A0D602ACD A98A8500338513 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] E3F51FC8BBE83A6470D0998911BA3F24D0DF3B6B [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Device ecid 0000f95c0c380026 disconnect detected! [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1E_ECID:0000F95C0C380026_IBFL:3 D_SRNM:[G99X1C03J6GF] [info] Arrival USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1E_ECID:0000F95C0C380026_IBFL:3 C_SRNM:[G99X1C03J6GF] [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.60.62 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-82340-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15184 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-82340-072.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (77555042 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (33394 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2296350 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13244106 bytes)... [info] Device ecid 0000f95c0c380026 disconnect detected! [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CP FM:03_SCEP:01_BDID:1E_ECID:0000F95C0C380026_IBFL:3 C_SRNM:[G99X1C03J6GF] silent [info] Arrival USB\VID_05AC&PID_12AF\E5484460310ED945A802406CD9AF 7740B7C30A74 silent [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e5484460310ed945a802406cd9af7740b7c30a74 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 30 [info] ChipID: 32772 [info] UniqueChipID: 274173737304102 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49162) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Connecting to FDR client at port 49162 [info] FDR 0CDBC5D0 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49162 [info] FDR 09C1C9E8 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49162 [info] FDR 09C1C988 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49162 [info] FDR 09C1CA18 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49162 [info] FDR 09C1C928 Proxy connect request to skl.apple.com:443 [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-82340-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-82387-072.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [erro] FDR 09C1C988 Unable to receive proxy payload (-4) [erro] Could not read data (-256). Aborting. [erro] FDR 0CDBC5D0 Unable to receive proxy payload (-4) [erro] Unable to restore device [erro] FDR 09C1CA18 Unable to receive proxy payload (-4) [erro] FDR 09C1C928 Unable to receive proxy payload (-4) [erro] FDR 09C1C9E8 Unable to receive proxy payload (-4) [info] Removing USB\VID_05AC&PID_12AF\E5484460310ED945A802406CD9AF 7740B7C30A74 [info] device disconnect... [done] Operation finished! |
