03-12-2021, 06:03 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | (LOG) Apple Watch S3 38mm LTE [info] Using LOCAL IPSW C:\MFC_Watch3,1_7.3_18S801_n111sap_GPS_Cellular_Re store_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.3 [data] Product Build: 18S801 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00114dc6386840a6 [info] Getting ApNonce in dfu mode... [data] F89FB7F121553FE1A9F3AFC1BD5DB7077D235F001249678CD4 0D507575F43268 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 21D80E2016DAC5657AD61DF77DED850DFE98E46C [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch3,1_7.3_18S801_n111sap_GPS_Cellular_Resto re_38mm/038-95706-058.dmg [info] Extracting filesystem [info] Found ECID 00114dc6386840a6 [info] Getting ApNonce in dfu mode... [data] F89FB7F121553FE1A9F3AFC1BD5DB7077D235F001249678CD4 0D507575F43268 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 21D80E2016DAC5657AD61DF77DED850DFE98E46C [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (760868 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 00114dc6386840a6 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: f8 9f b7 f1 21 55 3f e1 a9 f3 af c1 bd 5d b7 07 7d 23 5f 00 12 49 67 8c d4 0d 50 75 75 f4 32 68 [info] Extracting iBEC.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (760868 bytes)... [info] Device ecid 00114dc6386840a6 disconnect detected! [info] device serial number is FH7VP2X8J6DW [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.80.19 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8783 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-95880-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15184 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-95880-059.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (77575522 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (33388 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2304542 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13255286 bytes)... [info] Device ecid 00114dc6386840a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device ba0e78bb715c66d15b774a09af676bad5d5859fd has successfully entered restore mode [info] Hardware Information: [info] BoardID: 28 [info] ChipID: 32772 [info] UniqueChipID: 4870588349300902 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49158 [info] FDR 09F92EF0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 09F92E90 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856D78 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856D78 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856B98 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856D90 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856D48 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 09F932E0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856C28 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 09F93160 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 09F933A0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 117B00F8 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 09F93118 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 117B00E0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856AF0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856C88 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856B80 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 09F93130 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856B50 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856C70 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856C88 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856E38 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856F70 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12857060 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12857048 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 128570D8 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DDF6D90 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0DDF6BE0 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12856F88 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 12857048 Proxy connect request to iphonesubmissions.apple.com:443 [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m8p_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting aopfw-m8paop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N111s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-95880-059.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-95706-058.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm4.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@115~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n111s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n111sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@115~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [info] device arrival... found. |
The Following User Says Thank You to oljack For This Useful Post: |
