10-07-2022, 11:23 | #1 (permalink) |
Junior Member Join Date: Sep 2022 Location: Jalandhar
Member: 3019950 Status: Offline Thanks Meter: 0 | series (SE) 40mm Unable to watch restore [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch SE, n140sap, Watch5,9 [erro] Can't find major version?! [erro] can't get URL for latest firmware [done] Operation finished! [info] Using LOCAL IPSW C:\Users\shopp\Downloads\MFC_Watch5,9_19U66_8.7_n1 40sap_GPS_Restore_40mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch SE, n140sap, Watch5,9 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.7 [data] Product Build: 19U66 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001a531621a3402e [info] Getting ApNonce in dfu mode... [data] EF9696954F8CE57C5446FC65ECFA0139D72D6817F63DB7D258 525AAFC63A366B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] BCAB5E8AC6F0F1DB9C5E8B763FC991D2CEA01AB8 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs Filesystem file not found! We will extract the filesystem to file iDeviceTools/MFC_Watch5,9_19U66_8.7_n140sap_GPS_Restore_40mm/078-33105-073.dmg [info] Extracting filesystem [info] Found ECID 001a531621a3402e [info] Getting ApNonce in dfu mode... [data] EF9696954F8CE57C5446FC65ECFA0139D72D6817F63DB7D258 525AAFC63A366B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] BCAB5E8AC6F0F1DB9C5E8B763FC991D2CEA01AB8 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n140s.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1162693 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 001a531621a3402e disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: ef 96 96 95 4f 8c e5 7c 54 46 fc 65 ec fa 01 39 d7 2d 68 17 f6 3d b7 d2 58 52 5a af c6 3a 36 6b [info] Extracting iBEC.n140s.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1162693 bytes)... [info] Device ecid 001a531621a3402e disconnect detected! [info] device serial number is G99FVC6SQ07R [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7459.140.15 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@394~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10138 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1846417 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1906601 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1731605 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-n140aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (2071701 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (897469 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 078-33402-075.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16754 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20173 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1176673 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31860 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 078-33402-075.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (88987800 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n140sap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (42861 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n140s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5463422 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch5... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (13479465 bytes)... [info] Device ecid 001a531621a3402e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-001A531621A3402E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 40 [info] ChipID: 32774 [info] UniqueChipID: 7409703913209902 [info] ProductionMode: true [sett] Previous restore exit status: 256 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49159) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Updating NAND Firmware (58) [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n140s.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@394~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n140s.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n140sap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@394~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n140s.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n140s.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n140s.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1699 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49159 [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49159 [info] FDR 08834090 Proxy connect request to xp.apple.com:443 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [erro] FDR 08834090 Unable to receive proxy payload (-3) [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-n140aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting 078-33105-073.dmg.mtree... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N140S_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N140s_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 078-33402-075.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 078-33105-073.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Extracting 078-33105-073.dmg.root_hash... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 18446744073709551615 [info] Checkpoint 1589 complete with code 56 [info] Checkpoint 1659 complete with code 56 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Ramrod firmware update failed. Hint: The display of this model is not compatible, or you can replace the NFC module [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [info] Checkpoint 1608 complete with code 0 [erro] Unable to restore device [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\00008006-001A531621A3402E |
